Old 12-26-2003, 03:02 AM   #1
69_hafton
Sleep-Deprived
69_hafton's Avatar
Question Is there a hood center support?
The center of my OEM style hood jumps up and down when
going over bumps. I thought I'd seen a picture of a
show truck with a support that goes between the two
I-beam supports that are on the original hoods. But
I haven't seen any advertised anywhere or offer online.
Anyone know of such a thing? Maybe it was just another
custom piece on the truck I'd seen.
69_hafton is offline   Reply With Quote
Old 12-26-2003, 04:17 AM   #2
krue
Designated A-hole!
krue's Avatar
Mine has a couple of pieces of cardboard. I guess you could call that "custom".
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-26-2003, 05:11 AM   #3
1969 GMC
1969 GMC's Avatar
My hood does that "bounce" thing too, but there is a nasty dent where it looks like the p/o dropped something pretty heavy on it. The frame is bent downwards slightly, and there are some wooden shims shoved in between the sheetmetal and frame. I always thought if it was right, it shouldn't bounce.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-26-2003, 06:41 AM   #4
JimKshortstep4x4
Talking
I don't have a picture of it, but one of the board members installed a center brace using an old hood brace. It looked real factory and he put the rubber strip in between the brace and hood so that the brace would hold the hood in the center.
Apparantly there has been a lot of hoods sat on and the center is depressed with the stiffness reduced so they shake. You will want to make sure that the original rubber strips are in place as they will move out of position sometimes. The rubber strips are available from the vendors.
We used a hood brace from a truck hood to brace the center of a 56 Chevy car hood that had been sat on. It works really well and looks like it belongs there.
Here is a pic of the home made brace that I made up to stop the hood shake in the middle. It works but it is not as slick as using a hood brace off of a junk hood.
Jim
Old 12-26-2003, 08:02 AM   #5
PR454SS
PR454SS's Avatar
Now I'm confused, don't all hoods come with a center brace that has a rubber seal underneath it???
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-26-2003, 11:34 AM   #6
69_hafton
Sleep-Deprived
69_hafton's Avatar
I'll check the rubber shims, I remember at least one that
is slipped out slightly. I don't have any dents that would have
caused any weakness, but who knows with an old piece of sheetmetal?
I'll have to watch for a hood that has a center brace that looks
useable. I guess I could do a fix like yours Jim, but my temporary
fixes usually become rather permanent.
PR454SS, does your hood have a center brace? What year is it
from? Mine is a '71 or '72 hood without a center brace.
Old 12-26-2003, 03:19 PM   #7
PR454SS
PR454SS's Avatar
from? Mine is a '71 or '72 hood without a center brace. [/B][/QUOTE]
Never mind I WAS confused I was thinking of the two outer braces that have the rubber seals in them.
Old 12-26-2003, 03:51 PM   #8
Sweet72
Sweet72's Avatar
Replace the old foam-rubber strips and secure them with 3M weatherstrip cement. Make sure your hood bumpers and latch are adjusted correctly as well. This made a world of difference in my hood. Our trucks never came with any such brace, and should be strong enough without one as long as there's no structural damage.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-26-2003, 09:32 PM   #9
69_hafton
Sleep-Deprived
69_hafton's Avatar
Sweet72, I took a look at the foam strips and they've
slipped to one side or the other and definitely need
replaced.
I hadn't thought of the hood stops, that's a good point -
I'll have to check those again after I get the strips
glued in place. They appear to be adjusted correctly.
After seeing the condition of the foam rubber strips,
I really think that they're the problem. I don't know
why I though they were OK? Selective memory?
Old 12-27-2003, 04:48 AM   #10
Bermblaster
This is how I got rid of the hood ripple when driving. I cut 1 inch square tubing with plasma cutter in half length wise. I welded to the existing hood braces only. I used a non expanding sealant to fill the gap between the new braces and the hood. Also I sealed inside of the original braces and hood. This needs to be done with the hood installed so the sheet metal of the hood will be in its original lay position. If you plan on painting the underside of the hood make sure the sealant is compatible. When I shut the hood It sounds like a new truck. NOTE: This mod may change the folding characteristics of your hood if you are in an accident. My truck is a 4x4 so I am not to concerned. My hood is ripple free while on the roughest roads.
"70" Chevy 4X4 Short Step
"68" Mustang
"03" FORD 4X4 V10
Bermblaster is offline   Reply With Quote
Old 12-27-2003, 04:52 AM   #11
Bermblaster
Here is a photo.
"68" Mustang
"03" FORD 4X4 V10
Old 12-27-2003, 04:54 AM   #12
Bermblaster
Different angle. Hope this helps.
"68" Mustang
"03" FORD 4X4 V10
Old 12-27-2003, 11:01 AM   #13
69_hafton
Sleep-Deprived
69_hafton's Avatar
Bermblaster, that's a very clean install! The
folding characteristics aren't something I'd
thought about. I do plan long term to lower my
truck, so I think I should leave the hood the
as close to original for now.
Note to self: clean and paint underside of hood.
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
