Old 12-26-2003, 04:40 AM   #1
TIMSPEED
TIMSPEED's Avatar
What's the difference between Manual & Electric Valves?
I honestly don't know
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-26-2003, 04:45 AM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Manual valves are operated by a switch that internally lets the pressure through as you toggle it. Electric valves work on a actuator type plunger. The switch (electric) is pressed and it sends power to the plunger and it moves one way or the other depending on up or down or type of valve used. Electric is much faster and alot less PITA!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-26-2003, 04:47 AM   #3
Injected68LS1
Injected68LS1's Avatar
A manual valve is just that, it's a valve that you open, by hand, with a lever attached to the valve. A good example is a water faucet.
An electric valve is one that is activated remotely by a electrical solenoid. Usually by pushing a button or switch.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-26-2003, 04:48 AM   #4
TIMSPEED
TIMSPEED's Avatar
So with an Electric Valve setup, I could mount the valves somewhere out of sight (like under the bed or something) and then just run the wiring into the cab, so I could toggle them?
See Them Here
Old 12-26-2003, 05:06 AM   #5
Injected68LS1
You got it. Out of sight and out of mind(until you push the switch).
