Guest
Posts: n/a
Dana wheel bearing setup
I found this helpful thread http://67-72chevytrucks.com/vboard/s...d.php?t=787982
I can't quite read the final end play spec is it 1 to 10 thou? Thought it might be 18 thou I'm finding that I need to back the inner nut off more than 1/4 turn after second torque to end up with any end play at all. |
![]() Join Date: Mar 2003
Re: Dana wheel bearing setup
No end play unless you mean to do so before the outer nut is tightened. There is slop in the threads of the nut. I make sure that the bearings are seated by tightening the inner nut while turning the hub, then backing it off and turning it until it stops. I then put the washer on then tighten the outer nut tight, fold the washer over and call it done. Never had an issue in 40 years. What you want in the end is not a lot of preload on the bearings, but you don't want the hub with end play either
![]() Join Date: Mar 2015
I belive the .001 to .010 is correct. This is the axial play and indicated the bearings internal clearance. I would use the tighter side of this specification. I'm finding that I need to back the inner nut off more than 1/4 turn after second torque to end up with any end play at all.[/quote] The second torque is just a specification for the second nut. it's only function is only to lock the first nut in-place. Is the washer with the tab on it there? It is designed to keep the first nut in place while you tighten the lock nut. Sounds like you are rotation both nuts when tightening the second nut? Cheers. |
There is actually a few thousandths of end play in the nuts. So even though the nut doesn't turn, when you tighten one against the other it will move inwards some
Guest
Posts: n/a
Thanks guys, I'll shoot for low to no end play. I do have the tabbed lock washers in there.
