Is this everything I need to bag my 75?
Aside from a stepnotch (which I'll have made)
Is this a complete parts list? 1.) ARF11800 "Cool Ride" Kit for 73-87 C10 = $524 ![]() 2.) ARS14500 Parallel 4-Link with Weld-On Bag Mounts = $799 ![]() 3.) ARC4700 "BIG RED" Compressor System = $1495 ![]() So, for all the parts it would be something like $2818 + Tax and Shipping and such...right? Seems like it would also be a pretty straight forward install job too... |
Trucker.
That's it and I'd suggest you mount those outside the frame because we tried mounting mine inbetween the rails and the mounts are too wide and get into the differential and you're not supposed to weld to it since it's cast.
Happy to be here
![]() Join Date: Mar 2000
There ya go! That's everything you need. I would suggest a couple of things to consider though.
I'm not sure what air tank that is, but it looks like either a 3 or 7 gallon because of the shape. I suggest two 5 gallon tanks instead. The 5 gallon tanks are longer, but not as big around. They hide better if you install them under the truck. Since you are using a 4 link, you should be able to mount them outside the frame rails behind the axle. I would also delete the shocks from the kit. If there is a place that they compromise quality in the kit, it's the shocks. Get a credit, and buy your own.... ![]()
Under construction!
N2TRUX---That is a 5-gallon air tank.
![]() TIMSPEED---This setup looks familiar! Including the PST front-end kit and DJM spindles we both have. ![]() ![]()
2001 Silverado bagged on 22's. *Sold* |
#5 | |
Happy to be here
TIMSPEED he is right about the upgrade. That wasn't an option when I bought the kit for my 77. The extra compressor and air tank make that a pretty decent deal alone.... ![]() |
Signals in the bumper.
How long are the bars on that 4-link kit?
Will you have to relocate your fuel tank? N2TRUX, what shocks are you using?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#7 | |
Trucker.
When I bought mine, I was told that there was 30" bar option and 20" bar option. With the 20" bar you would not have to relocate the fuel tank. I was just wondering if they told him that too.
Not sure if this is true or not, but I had to relocate my tank. I asked for the 30" bars, but I never did measure them to check.
#9 | |
Trucker.
what would be the advantage of the longer ones? Ride quality? You wouldn't gain more or less lift as the bags are not mounted to the 4 link like a 2 link right? Just curious as i am ordering mine soon.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! ![]() |
#11 | |
Happy to be here
