Old 09-19-2021, 02:13 PM   #1
65chevysub
65chevysub's Avatar
tube from blower motor to heater box
Is a salvage yard the only place to find the plastic elbow/tube that goes from the blower motor to the heater box, or are they available online somewhere? Mine fell off, and I can't seem to find them anywhere.
65chevysub is offline   Reply With Quote
Old 09-20-2021, 12:50 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: tube from blower motor to heater box
That one of the best or E-bay, GM Dealer parts may still have some. Not sure if Chevrolet classic parts may have them.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-22-2021, 09:52 PM   #3
65chevysub
65chevysub's Avatar
Thanks Pontiac 1976. I'll check ebay
Old 09-23-2021, 07:56 PM   #4
SilverMiner
SilverMiner's Avatar
Out of curiosity I searched the "Parts and Illustration Catalog" 1979-1984 (you didn't mention what year your truck was) and I was not able to find a part number for that elbow although I do believe I know what you're referring to.
I believe that hose is intended to provide cooling for the electric fan motor, so I would look go to the hardware store and hunt up some generic hose of the proper diameter. But that is only if a junk-yard search fails, because one should be easily found there. I don't suspect many others will have been previously snagged.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
