T Fitting For Hydraulic Brake Controller ?
I have this brass fitting plumed into the front port on my master cylinder. The line exiting goes to a trail brake controller. If I unscrew the line and plug it quickly will I have to bleed the entire system ? The controller itself is starting to leak inside the cab...thanks
71 C-20 07 Magnum RT AWD |
