09-20-2021, 10:30 AM | #1 |
Full length windshield
Who sells those type of windshield's? You see them in 67 8 and 9 Camaro's and I'm sure other vehicle's. It doesn't use a gasket I believe its glued in.
Thought of putting one in my blazer. Thanxs
Things happen for a reason! |
09-20-2021, 10:44 AM | #2 |
Re: Full length windshield
i know theyre around for the rear window as well but i do not know who made these. but man those are a nice touch
1967custom |
09-20-2021, 10:48 AM | #3 |
Here's a link to one option. I know nothing of the vendor and be prepared for some sticker shock...
https://www.shopfesler.com/collectio...less-glass-kit
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
09-20-2021, 11:17 AM | #4 |
Same glass but this guy has them in stock also...
https://www.vannattafabrication.com/...ass-p144963256 |
09-20-2021, 12:02 PM | #5 |
That actually looks kind of slick, but too rich for my blood
1968 GMC C2500 Long Bed Fleetside |
09-20-2021, 02:42 PM | #6 |
Far to rich for me mt last one cost 80 in Canucks bucks shaded and tinted
09-20-2021, 05:33 PM | #7 |
Since the factory rubber channel is also the finish trim on the inside, what do you do about covering the exposed pinch weld that you glue the glass to on the inside?
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
09-21-2021, 08:29 AM | #8 |
Since these trucks were manufactured at multiple locations from different machinery there are tons of slight differences between one cab and the next.
The "flush fit" windshields typically require a bit of metal work on the cab around the windshield to make it fit properly. The pinch weld in some cases has to be extended to allow for proper sealing to the glass by way of a pinch weld gasket. The glass is bonded to the gasket using a urethane glue. The pinch weld and gasket are "hidden" by a black band of material called frit. The frit is usually an epoxy based paint which is baked onto the glass to provide an etched surface that allows adhesive to bond to the glass. Look at any current vehicle, and you will see frit around each sealed window surface. I think the flush fit windshields look good on customized trucks, but for me, the juice was not worth the squeeze. On the inside the pinch weld gasket looks pretty much like a regular windshield gasket. Here's a pic of my flush fit rear window from the inside. The pinch weld gasket is just above the seat back, the frit is between the gasket and the C/10 Club decal. Last edited by Zeroman; 09-21-2021 at 08:44 AM. |
09-21-2021, 10:32 AM | #9 |
Don't get me wrong...I don't mind spending good money on classic cars / trucks but, at $ 1,600.00 a pop I don't think I could get that mad at it.
09-21-2021, 10:51 AM | #10 |
Thanxs guy's fr the information......
09-21-2021, 02:39 PM | #11 |
Post Whore
I have no direct experience with this type of windshield for our trucks. But I have heard a lot of bad press about the same kind of glass for 2nd generation Firebirds and Camaros. All the dissatisfaction seemed to be about the quality of the glass (Wavy) and the large amount of body work involved to get a good fit.
I'm just providing a note of caution if someone is looking seriously at this conversion nothing more.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
