Old 09-20-2021, 10:51 AM   #1
blazer2007
drum brake drags after going in reverse ?
When I back out of driveway and go forward the brakes will grab real fast with little brake pressure and then will go back to normal after a couple of taps on the brakes within a block or two. It only does this when close to freezing with moisture in the air. It never does it in the summer just in the fall when the weather gets colder in the mornings. I took drum off but don,t see anything out of the ordinary . Thinking the wheel adjuster is getting stuck maybe or wheel cylinder . Still some meat on the shoes. Drum sits nice on the brake shoes. Other than this the brakes work fine.
blazer2007 is offline   Reply With Quote
