Window sash lubrication
What are you guys using to lubricate where the rollers go in the window sash for the side glass?
I am installing new side glass in one of my blazers soon and I’d prefer to do it once and correct. Thanks Mark Will it be a problem if the sash is installed about 3/16 to 1/4 inch forward on the glass? My glass guy who is a friend just centered it and an original glass I removed from another door shows it a little more to the rear. I don’t want to make him redo it if it’s not needed. And I also don’t want to install it to find out he needs to redo it?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: Jan 2013
Re: Window sash lubrication
I use Dielectric grease. It seems to work well.
![]() Join Date: Jan 2001
White lithium grease is what I always used in my glass shop.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Dec 2013
White lithium grease .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I've replaced a lot of side windows on a lot of different cars and always lubed window regulators with Valvoline synthetic grease. It sticks and doesn't get hard, even in cold temperatures. For the glass run channels, I always clean them really well and wipe on a tiny amount of silicone lube. Doing that will even make an old window work better than a new car.
Thanks gentlemen. Any thoughts on the sash placement mentioned above.
centered , about 3/4" from the edge of the glass .
