09-21-2021, 12:28 PM | #1 |
Long rear brake line leaks
I purchased an installed the Long rear brake line over 6 months ago. Went to bleed the brakes yesterday and found a leak. It is right in the middle of the line. In the area where I straightened it out from the shipping bend. It isn't stainless steel tubing. I was careful and rolled out the bend on a piece of plywood when I straighten it out. Looks like the hole may be at the seam? the leak is only visible while it is pressurized. I plan on double flaring the existing tubing, while it's installed, and adding a 36 inch section to the end of it. This is a new one on me. Does China make tubing?
Cheers. |
09-21-2021, 02:19 PM | #3 | |
Re: Long rear brake line leaks
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
09-21-2021, 05:15 PM | #4 |
I use AGS for all my brake lines & fittings. Never been disappointed, been using them since I was a kid. Most local auto part store stock the fittings and poly-armor sticks 12-48"long. They sell stainless and copper-nickle coils for a reasonable price. Everything product I bought from them was made in USA.
https://agscompany.com/product-categ...ll-coils-pipe/
Made in America by Americans |
