help identifying short or long water pump
Im visiting my brother out of state and he is giving me a ton of new parts for my SBC. I was just hoping someone could identify what my water pump is. These are the only pics I have of mine and I cant measure it since I am not home. I just didn't want to take parts that didn't fit.
If it helps the pictures show my truck. The alternator sits high on the drivers side, power steering pump sits right under that. My truck use to have the AC compressor on the passengers side but that was removed by the PO. Any help would be great. Thank you |
Re: help identifying short or long water pump
short
water
(use images not text to compare) Last edited by Warrens69GMC; 09-21-2021 at 08:33 PM. Reason: incorrect text |
Is it possible to have a BB short water pump on a SBC engine? Because according to the picture my would be a BB water pump. Am I looking at it wrong? Its also weird that my truck is a 1972 which states they switched to the long water pump. My short block 350 was turned into a 383 though so maybe that's the reason for the above mentioned. I just don't know though. Hopefully I can learn something new
No. Some of the Short Water pumps are drilled and some are not
Yours is drilled, and has a plug in it. Here is a 307, same water pump as 350, short water pump and plugged http://67-72chevytrucks.com/vboard/s...89&postcount=8 |
#7 | |
I want to say it was for the larger SWP trucks. C40/C50/C60
#9 | |
Who's got steelies?
![]() Join Date: Feb 2006
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Heater hose connections on certain applications.
#11 | |
short pump
#13 |
Who Changed This?
![]() Join Date: Jan 2013
That would be when 454 engines started getting installed in trucks? The reason I ask is because I'm looking to replace the 402 in my truck, as it is getting tired. If there is a 454 with a short pump like my truck has, that would be great. Otherwise I'll have to move the engine back, and that's not a pleasant prospect.
#14 | |
#15 |
Who Changed This?
Thanks for the info! I posted a WTB earlier. I'm looking to increase power without going bonkers expensive.
