Mr. Cheyenne
![]() Join Date: Jun 2020
LMC Heavy Duty Headlight Harness Water in Relay
About a year ago I got LMC's Heavy Duty Headlight Harness, part number 36-3580 but installed it some months after receiving it. So it is less than a year I think in my truck. I likely have under 5 hours of driving time at night.
After one of my truck washes, my lights started to flicker. Then over the weekend my High Beams actually turned off my lights. I reached out to LMC stating I thought I had some bad relays, which they just reported back to me "we sell replacements". Gee, thanks but I knew that - so they don't seem to care about standing behind the stuff they sell. Anyways, I ordered two relays but while waiting for them to get here I decided to open up the problem relay. Which was rather easy as the cover isn't really sealed onto the base. As you can see with the photos, water has gotten into the relay and made a mess of things. Do note, the only water that gets on my truck is when I wash it and it stays in my garage. So never has rain (other some very light rain) hit my truck since installing this harness. I got the relay working again but it took me using my Relay File (what I used to clean contacts on a EM Pinball machines). When cleaning relay contacts you shouldn't just use a normal file. Well you can but then you'll damage the relay contact pads and that can cause arcing that leads to the relay decay (but so does water). Anyways, perhaps this will help someone else.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#2 | ||
Mr. Cheyenne
Re: LMC Heavy Duty Headlight Harness Water in Relay
Got another response from LMC:
Edit: Another email (which they sent out a "recall the previous replay" email). hank you for reaching out to us, Quote:
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 09-22-2021 at 12:07 PM. |
Where do/did you have your relays mounted on your truck, on the grill side of the firewall exposed to the elements? in the engine compartment? I can't speak to the LMC relay harness because I built my own but when I did, I used "weather pack" type relays to avoid any issue with debris, moisture etc., getting into the relays. I have mine mounted on the grill side of the firewall, exposed to all the elements including water from rain, road grime, car washes, etc., and it's worked flawlessly for years now.
https://www.summitracing.com/parts/p...CABEgKEXfD_BwE
66 GMC Suburban Custom 66 Chevy K10 Suburban |
One of the reasons I don't like car washes. Water under pressure does lots of damage. Technically, under warranty or not, the relays' failure falls under misuse or improperly installed.. You probably mounted them with the plug facing up and water got in.. It's nice of LMC to reconsider and send you some replacements.. Mount the new ones with the plugs facing down and water won't encroach..
Mr. Cheyenne
They are mounted inside, between the passenger fender and battery - facing down and inside the engine compartment. Who would mount any relay upside down to expose the connector easily to the elements? That would be nuts but thank you for implying that I am :p
I never go to a car wash, I use my water hose under house water pressure. I also haven't washed directly into my engine compartment. So all this water has worked its way from washing from the outside. Though I do spray directly into the grill/front of the hood. Which is where water would get to the area my relays are mounted. If I mounted the relays forward of the battery (say on the inside passenger fender) I'd get the same amount of water splash/drip. There isn't that much length I think to go anywhere else to mount the relays. So I don't think this is a case of "misuse or improperly installed". These relays should be sealed and by me pulling the cover off, there aren't sealed (cover glued to base).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 09-22-2021 at 01:05 PM. |
Mr. Cheyenne
Okay, so I decided to open up the other relay, which butts up right to the other "rusty" relay. This one was a bit harder to pull apart but not by much. There is no indication water has even gotten into this one.
Edit: This is where I have them installed, on the brace between the passenger fender and the battery.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 09-22-2021 at 01:04 PM. |
It's possible the issue may return even with replacement relays, I don't think the relays that come with the LMC harness are "weather tight". I'm basing that on the pic of the LMC heavy duty harness/relays in this thread. You'll have to keep eye on it but you could easily substitute them for the "weather pack" type if the issue returns again. Good luck!
Mr. Cheyenne
agreed, these aren't water tight at all. When I installed the harness, I wrapped all the plugs with electrical tape but I didn't do anything to the relays themselves. I didn't think the relay's themselves would get water in them. These should be water tight, IMO.
I am sealing these original relays with Epoxy 2-part glue. Unless the cover is compromised, no water is getting into them now. I'll keep the replacements (will also be sealed with epoxy by me) as spares.
Sounds like a solid plan and hope it provides trouble free operation for you. Of course now I have to ask, what type of headlights are you running and what is your experience with your setup since installing the relay harness?
Mr. Cheyenne
Aside from the relay drama, I love the setup but I should have done it myself for water tightness. Just another example as doing things "easy" can bite you in your arse later LOL
As for my headlights, see this thread on Dapper LEDs, https://67-72chevytrucks.com/vboard/...ghlight=dapper
#11 | |
Post Whore
![]() Join Date: Feb 2016
In non-water tight relays the connectors and other components are installed in preformed holes in the base after it is molded. If the connectors look good and clean it is possible that the moisture came pre-installed from the factory.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 09-22-2021 at 02:04 PM. |
Those are called 'Bosch relays' even though the ones you have aren't made by Bosch. If they fail again try using actual Bosch relays.
#13 |
I purchased the harness from LMC or maybe on of their competitors, cannot remember. The relays supplied are definitely not intended for wet locations and should be mounted in a weather proof (fuse) box. Also, the small triangle brace will see water during washes and rains. I mounted mine to the side of the batter box in the "normal" rotation and all is well. The relays are cheap and probably a good idea to have a few spares on hand.
#14 |
Mr. Cheyenne
I think the relays will be fine now that I have them sealed up with epoxy between its cover and base. Though if not, I'll break out the spares that I'll end up with and adjust the mounting location!
At the time of mounting the relays, I thought I was being clever with the location for easy access and no strain on the wiring. Hindsight is 20-20, as it always is!
#15 |
![]() Join Date: Dec 2014
I just purchased and received my GMC headlight relay kit from LMC. I bought it because my 72 is the one classic vehicle that I think I will drive in the winter, and winters are DARK here.
My mechanic friend is extremely skeptical of the product, maybe he is right. I know that people who are handy can simply make their own headlight kit but I bought mine because I am not that person.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#16 |
Mr. Cheyenne
I remember when I got the kit, I wasn't all that impressed either.
Get yourself some 2-part epoxy to seal around the cover and the base. Though I popped off my covers and placed epoxy (carefully) around the base, put the cover back on, and ran epoxy around the seam. It was real easy to pop the covers off, which is why water can get inside. Then I'd get some good electrical tape to wrap all the connectors, then I also used over the electrical tape engine wiring tape, it's fabric like. I think if you keep the water out, the relays will be fine but only time will tell.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 09-22-2021 at 03:25 PM. |
#17 | |
#18 |
Mr. Cheyenne
yep, it sure does. Big improvement over running the power through the dash switch. Until I had relay issues, I thought the kit was the best thing since sliced bread!
#19 |
Post Whore
If you're building your own or want to upgrade.
https://www.amazon.com/PACK-AMP-Wate.../dp/B074FSZWVT
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#20 |
Mr. Cheyenne
those look the good ones to me, I might update to those.
#21 |
I wouldn't tape up the relay plugs. You're just going to trap the water in there. GM used those Bosch type relays with open plugs for years with relatively few problems.
You lost one relay. Doesn't seem like a major problem. I get my relays and plugs for may different applications from the wrecking yards. Under the hood of any 80s GM auto and you will find at least a half dozen of those type relays. I placed the fan relays in my truck in the same location you used and the headlight relays in an even less protected location on the other fender.
'67 GMC 2500, 292, 4spd, AC |
#22 | |
#23 | |
![]() Join Date: Jan 2003
If you came to any store that I know and ask for a Bosch relay, you would get handed one of these.
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
#24 |
I work in automotive engineering and regardless of the number of poles, we call them Bosch relays because of the form factor.
#25 |
Do you refer to r134 of r1234yf as Freon then?
