Old 09-22-2021, 06:25 PM   #1
gregbr
Senoir Member
gregbr's Avatar
NP205 side mount to frame ???
I've heard many people say not to use the 205 side mount bracket that connects to the frame. What's the pros and cons of using the side mount brace?
That heavy 205 hanging there by only the adapter plate seems like a problem too. Then again, the side mount doesn't look like it helps a lot.... probably just keeping it from twisting from torque.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 09-22-2021, 07:12 PM   #2
kwmech
Re: NP205 side mount to frame ???
I've seen issues both ways. The real issue seems to be the type of 'wheelin' done in 4wd. If you are doing somethings extreme like rock crawling or deep frame twisting yeah you're gonna have a problem. Remove it to prevent breaking the adapter or tear the back part of the trans in half. OR have the same thing possibly happen b'cuz of the weight. GM went back and forth on this. I think if the rig is maintained, nuts and bolts kept tight and oil leaks repaired to keep mounts from deteriorating will greatly reduce damage. I've had trucks come in with all the mounts sagged out, tons of leaks that the mud soaked that takes a putty knife to find the head of the bolts. No breakage, no cracks- just clean it up and rebuild. then you have the clean truck that blows the whole thing all over the freeway. I know 1 thing though is keeping tabs on the front CV to prevent high speed vibration when driving in snow or accidentally leaving the hubs locked can create havoc also.
Old 09-22-2021, 07:17 PM   #3
truckster
truckster's Avatar
I can't really add to what KWMech said, except ditto. If the mounts are in good shape, you don't need the side bracket, and if they're not in good shape it's really not going to help.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-23-2021, 06:51 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I don't have one on my 72 because I was afraid of breaking the transmission's adapter. I have another one I was going to replace the bushings with poly ones but I can't think it would be a great idea. I just think it would be too stiff and eventually break the adapter too. This truck is a 72 4 speed and will have a plow on it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-23-2021, 08:12 AM   #5
57taskforce
All about them K’s
57taskforce's Avatar
I left the side mount off on my 72 K20 4 speed. My adaptor was still in really good shape when I pulled the transmission and transfer case to rebuild them, I intend to keep the adaptor healthy for a long time to come.
Tyler
57taskforce is offline   Reply With Quote
Old 09-23-2021, 08:35 AM   #6
MJN
MJN's Avatar
Reading the other replies I must be the odd man out and still running the torque mount on my 205....with poly bushings. Never had an issue- figure its had it for close to 50 years without failing the adapter or causing any other damage.
I had a mud truck in college with a SM465/NP205 and I left this mount off- I had to keep an eye on the adapter bolts from backing out. Given this one saw a rough life on the trail I would have rather had the torque mount in place than have to stop on the trail to tighten adapter bolts.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-23-2021, 10:39 AM   #7
Dieselwrencher
On my 72, the OD unit is the extension and is aluminum. This is why I left the side bracket off. Well, that and lots of horse torques. I don't want to have to pick up the 205 off the ground some day.
Ryan
Old 09-23-2021, 08:23 PM   #8
gregbr
Senoir Member
gregbr's Avatar
Thanks for the input. I have poly bushings & mounts for everything, but thinking about staying with rubber for the body mounts.
So it sounds like poly bushings, no leaks, keeping the mounts tight it should be ok to keep the side mount. And when finished it won't be going off-road.
