Old 12-26-2003, 12:55 PM   #1
chevyfan420
rear end ratio's
What gear sets will fit the carrier of a dana rearend that came with 3.73s. It came in a 72 GMC 3/4 ton
chevyfan420 is offline   Reply With Quote
Old 12-26-2003, 01:38 PM   #2
ABHaulR
ABHaulR's Avatar
is it a dana or a hd72? does it have a drop out 3rd member? if it drops out the only ratio you can get up to is a 4:10. dont know if that helps you.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 12-28-2003, 03:44 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It is aftermarket or swapped in from something else, 3.73 was not offered in 3/4 ton trucks.
It may be out of a later dodge or an aftermarket unit.
Old 12-28-2003, 04:54 AM   #4
1969 GMC
1969 GMC's Avatar
is your truck an original Big Block euipped truck?
if so, they had 3.54 gears in the dana 60 factory. otherwise, they should have 4.11 gears in a 3/4 ton. i am not sure if the 4.56 came in the dana 60 rearend, perhaps as an option. I am not sure about the gearsets you could get, I am guessing you have a 3-series carrier that will hold all 3:_ _ gears. maybe someone else can help.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-29-2003, 12:31 PM   #5
chevyfan420
the truck is an original 250, three on the tree. as far as i know the 3.73 is original
