Old 09-25-2021, 01:34 PM   #1
64stpside
Do I need to add a fuse??
I'm wiring a fuel pump/oil pressure safety switch on my 64c10 using this layout:
https://www.tanksinc.com/pdf/fuel_pu...structions.pdf
I need to run a wire to the "I" terminal part of the switch.
Do I need a fuse on that wire to the "I" terminal of the safety switch?
Is it a safer bet adding one even though the instructions don't say to use one?
If so, what amp fuse do I need?
64stpside is offline   Reply With Quote
