Old 09-25-2021, 07:49 PM   #1
61hawk
61hawk's Avatar
60-66 Tail Light Gas Filler
Someone on Facebook posted this so I'm just forwarding it over here. I have no affiliation with the company, just passing this along.
https://www.tiktok.com/@c10trucks/vi...41426016701702
https://c10crewcab.com/tail-light-fuel-filler
61hawk is offline   Reply With Quote
Old 10-02-2021, 12:49 AM   #2
Lokin4AReason
Lokin4AReason's Avatar
Re: 60-66 Tail Light Gas Filler
Be interesting is seeing at what the other kit(s) will go for . . .
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 10-07-2021, 02:41 AM   #3
donthekawguy
donthekawguy's Avatar
650 bucks? A little steep and I'm not a fan of led lights. It is a very cool idea. Mighthave to steal it and make my own while I have my truck blown apart. Lol
66 shorty
donthekawguy is offline   Reply With Quote
Old 10-07-2021, 08:33 AM   #4
MT65
It’s time consuming, but doable, did it last winter when I was laid up from broken leg…
MT65 is offline   Reply With Quote
Old 10-07-2021, 12:06 PM   #5
61hawk
61hawk's Avatar
I actually like your setup better. Their hinge looks a little wobbly in the video.
Old 10-07-2021, 01:53 PM   #6
MT65
Thanks…..
Old 10-30-2021, 04:31 PM   #7
65ChevyUtah
That looks awesome ! What hinge did you use?
65ChevyUtah is offline   Reply With Quote
Old 10-30-2021, 06:37 PM   #8
MT65
I wish I could just tell you a certain hinge…I made everything with the exception of the pivot pin, which is a solid pushrod from an early 392 hemi….used it so I would be able to drill and tap for the pivot point.
The rest is just trial and error to get the geometry correct, geometry was not one of my strong suits in school. I even made shims to tighten everything up, when it gets to extended length, it doesn’t take much to have too much play.
If you have time and access to a good salvage yard, it would most likely be easier….
If I can find the progress picture, I’ll send it to you
Old 10-30-2021, 07:31 PM   #9
MT65
Check your private message….
Old 11-06-2021, 02:11 PM   #10
Asshat
Asshat's Avatar
That's little too pricey for me. Very cool though.
I'm getting ready to install a tank in my 63.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-07-2021, 07:51 AM   #11
duallyjams
duallyjams's Avatar
just checked out the web site. Price drop, 579.99 and has a video of installed on a running truck.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-07-2021, 08:08 AM   #12
Asshat
Asshat's Avatar
Even at $579 it’s pricey.
I realize they did the engineering, but you still have to do a lot of cutting and some fabrication. If it was $250, I would buy it right away.
292, 4-speed
Old 11-09-2021, 12:24 AM   #13
65ChevyUtah
I ordered one. It arrives tomorrow. I’ll will see if I can post the instructions. I hope the cutting is doable without damaging the paint. I just finshed painting my truck.
Old 11-09-2021, 01:06 AM   #14
MT65
Would be interested in seeing the instructions and diagrams also…..
Old 11-09-2021, 10:15 AM   #15
61hawk
61hawk's Avatar
I'm interested to hear how stable it is once installed. I realize the light doesn't weigh all that much but with a side swinging single hinge it seems like it would be a little floppy vs. one that hinges down. Personal opinion, but I don't see $600 there.
Edit: Okay it looks like they stiffened up things since the TikTok video.
Old 11-09-2021, 11:55 AM   #16
Asshat
Asshat's Avatar
I would consider mounting the hinge at the top; it would alway stay closed, except when filling.
292, 4-speed
Old 11-09-2021, 10:42 PM   #17
Asshat
Asshat's Avatar
I cannot believe the cost of fuel fill hose. I may need about 5 feet, and a 6' piece from Rock Auto is $75, with shipping. What the hell??
Anyone know of a better place to get this hose?
If I use a connector, what material should it be - steel?
Is aluminum ok to use with gasoline?
292, 4-speed
Old 11-09-2021, 11:35 PM   #18
Asshat
Asshat's Avatar
Why do you need a vent tube in the new style filler necks while the original one on the C10 does not?
292, 4-speed
Old 11-10-2021, 12:22 AM   #19
cwcarpenter98
cwcarpenter98's Avatar
The in cab tank for 60-66 doesn't have a vent in the filler neck, but on the Suburban and Panel tank that's under the rear floor, it did have a vent tube that runs from the tank into the top of the filler neck.
A vent is good because it allows the fuel to expand and contract with the temperature without building too much pressure inside the tank. It'll probably help with ease of filling since the air being displaced by the fuel can go through the vent instead of out the filler neck that the fuel is trying to go down.
There's probably some other science-y reason I don't know about
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-10-2021, 01:09 AM   #20
MT65
What carpenter said about your next question 👍👍👍, for filler hose go to fillerhose.com, they have lots of hose, bends etc and filler necks…I used a piece of stainless for my tubing, aluminum would be fine though….
Old 11-10-2021, 04:25 AM   #21
Asshat
Asshat's Avatar
What carpenter said about your next question ������, for filler hose go to fillerhose.com, they have lots of hose, bends etc and filler necks…I used a piece of stainless for my tubing, aluminum would be fine though….
I think you mean fillernecksupply.com… can’t find fillerhose.com.
I did check fillernecksupply, they have it, but not cheap at all. A 5’ piece is about $78 shipped.
292, 4-speed
Old 11-10-2021, 04:30 AM   #22
Asshat
Asshat's Avatar
That makes sense, but still more questions.
If you do the tail light filler, you don’t really have room for a regular gas cap. Someone told me they would use fuel cell foam to plug it up. Is this adequate?
Will the vapors still escape and fill the garage?
Either way it seems a charcoal canister would be required to help vent the tank and keep vapors at bay.
292, 4-speed
Old 11-10-2021, 09:05 AM   #23
MT65
Correct on the fillernecksupply……lots of newer vehicles don’t use fuel caps, everything still vents, odor or not, they have a spring loaded cap and nothing twist on, find one of those. The fuel cell foam would work similar to the spring loaded one as it gets compressed into the neck, or I see one of the kits uses a boat style cap, it still has a vent somewhere, charcoal canister I would seriously doubt. Did your stock tank smell up the garage with vapors? Mine didn’t, to my knowledge there isn’t a hot rod or classic car or truck that is built EPA compliant, all those power train packages that GM sells complete with cats and computer, still vent the fuel tank to the atmosphere…your call, enjoy the project…
Old 11-10-2021, 09:09 PM   #24
Asshat
Asshat's Avatar
I do not get any fuel smell with the truck in the garage - stock tank.
I'm definitely not concerned with EPA stuff; I just want to be sure I don't get the gas smell and I want to be sure the tank is vented properly, to avoid pressure building up.
So. I'm thinking I would use my filler neck tube and add a port to the top that vents to the fill side on the tank. This semms alittle easier than spending $60 on a fill tube.
The think that really bugs me is the price of the 1-1/2" filler tube hose.
292, 4-speed
Old 11-10-2021, 10:04 PM   #25
65ChevyUtah
So I received the kit yesterday but the instructions are incomplete. I emailed c10crewcab and he replied back he is modifying the instructions and will email them over to tomorrow.
After looking at the kit it’s going to require a pretty good amount of time to remove the inner part of the stake pocket. I am hoping it won’t jeopardize the structural integrity of the bed by cutting it out. It does say on the website this isn’t a 1 hour job and requires some fabricating skills but this looks pretty intense. I am not a rookie fabricator but it’s gonna be tough cutting in such tight spaces. I am hoping the new instructions tell me what tools he used to cut it out. I’ll post an update with the instructions.
I am also worried a little about fuel flow since the fuel
Hose will be pretty much flat for about 18” before dropping into the tank. I wish they would have shown the whole install in their promo videos and in the picture.
If anyone is considering getting this kit you might hold off for a bit until a few of us have actually got it installed successfully and the instructions are updated.
