09-26-2021, 05:15 PM | #1 |
How do you change headlights in this truck?
These are frenched sealed beam headlights with no front access to the mounting ring. I assume the back can't be accessed because of the headlight bucket required for a sealed beam bulb. How would one change headlights?
1951 Chevy Panel Truck |
09-27-2021, 09:30 AM | #2 |
Re: How do you change headlights in this truck?
ive seen these installed with the mounting screws in the rear. requires removing the wheel for access but how often do we change headlights? Also have seen the buckets modifed with the adjustment screws in the rear.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
09-27-2021, 01:54 PM | #3 |
Just as Nvrdone said, Jack truck up and block it up, remove front wheel and get in under the fender and remove the bucket from the inside. I reversed the clips for the bucket screws on mine but would weld 1/4 inch bolts in if I did it again.
You have to put set things up right and adjust (aim) the headlights before you weld on the rings as you can't aim them later without a lot of hassle.
09-27-2021, 02:21 PM | #4 |
I'm thinking, you remove the fenders and put stock ones on. That's how you "change the headlights" LOL
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-28-2021, 09:11 AM | #5 |
martin - any one told you that you are a smart *** I love it !!!
09-28-2021, 10:49 AM | #6 | |
Brian
09-29-2021, 10:00 PM | #7 |
ive got a print out i found on the internet that shows how to change the adjustment screws so they access from the back. I know its here but where to find it ....
09-30-2021, 04:03 AM | #8 |
I could use that., I'm not sure how you would make adjustments except by guess and by golly though. It's an effort to get up under the fender on mine with the tire off, no getting under the truck when it is sitting on the shop floor.
09-30-2021, 06:27 AM | #9 |
i will see if I can find that print out & get you a copy.
