Old 10-01-2021, 12:59 PM   #1
cornerstone
cornerstone's Avatar
Glovebox emblem mounting question
This is my 1968 C50 glove box door. It has no holes on the backside of the inner panel to allow for nuts or retaining clips. I removed the door completely thinking there may be some secret entrance but to no avail. While I had the glove box door off I could hear the original emblem retaining nuts rolling around in there. Currently my thought is to use some sort of epoxy putty and blob it on the emblem tabs and press it in. Of course there’s always double sided tape too, but it got me to wondering, what would you do if you were aiming for a concours restoration? Peel back the pinch fold and separate the door halves?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-01-2021, 01:15 PM   #2
MySons68C20
MySons68C20's Avatar
Re: Glovebox emblem mounting question
Emblem adhesive. My 68 same way as yours.
MySons68C20 is offline   Reply With Quote
Old 10-01-2021, 01:21 PM   #3
MySons68C20
This is what I used.
Old 10-01-2021, 02:19 PM   #4
BigBird05
Since the door was painted before the emblem is installed GM must have used little barrel retainers. Check with NAPA. They should have some.
BigBird05 is offline   Reply With Quote
Old 10-01-2021, 03:52 PM   #5
cornerstone
Thanks MySons68C20!
Brian
Old 10-01-2021, 04:00 PM   #6
MySons68C20
My pleasure cornerstone!
Blake
Old 10-01-2021, 06:32 PM   #7
toms68cst
toms68cst's Avatar
Good (3M) double sided tape has held mine for 20+ years.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 10-01-2021, 06:53 PM   #8
michael bustamante
michael bustamante's Avatar
Im pretty sure barrel nuts were used to hold the emblem in but 3m tape should work just fine
1967custom
michael bustamante is offline   Reply With Quote
Old 10-01-2021, 08:52 PM   #9
FirstOwner69
FirstOwner69's Avatar
I've seen these push-in retainers used for similar applications. https://www.ebay.com/itm/32328646204...yABEgK4ifD_BwE
I'm not sure what was used for the glovebox though, and I don't know if these are the right size. I believe these are what Michael was referring to.
Jim
FirstOwner69 is offline   Reply With Quote
Old 01-22-2025, 07:54 PM   #10
IronCanine
I'm trying....
IronCanine's Avatar
Surprisingly I haven't seen this on the board. If I've missed it, apologies. But I thought I'd throw this out there for posterity.
I'm not well versed on 67/68s, but the 69 up emblems have 1/8" studs. You can get these tubular nuts most anyplace, including Amazon. The size for our gloveboxes (in my experience) is 1/8" stud for a 3/16" hole.
They push in. You may have do put a little pre squeeze on them if it feels like you're putting too much force on them to insert them. Then the emblem just pushes in.
No adhesive. No tape.
IronCanine is offline   Reply With Quote
