Old 10-01-2021, 02:25 PM   #1
custom10nut
custom10nut's Avatar
Panhard bar and sway bar question
Using other members post as a guide, I bought a Rear Sway Bar from a 95 Nissan Pathfinder, to mount on my 70 C-10.
When I mount this Sway Bar, do I need to leave the Factory Pan hard bar in place? Or would that be overkill?
Everything on the suspension is factory stock with exception to the Gabriel Coil-over shocks on front and rear.
I’m all ears
custom10nut is offline   Reply With Quote
Old 10-01-2021, 03:23 PM   #2
Richard
Re: Pay hard bar and sway bar question
I’m all ears
100% yes you need to leave the panhard bar. It locates the axle and prevents movement side to side. A swaybar does not have that capability. Swaybar just transfers weight from one side of the vehicle to the other.
Richard
Old 10-01-2021, 06:06 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Panhard bar and sway bar question
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-02-2021, 12:12 AM   #4
custom10nut
That’s what I was figuring. Thanks for the info
Old 10-03-2021, 06:08 PM   #5
SCOTI
SCOTI's Avatar
Sway Bars & Panhard bars have different functions.
A Panhard bar is a must for the T/A set-up. The sway bar can help or hurt depending on the set-up. They are not a Guarantee to be an improvement over not having one. They have been known to cause the rear end of a truck/car to come around quicker than expected when pushed to the limit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-03-2021, 06:12 PM   #6
70cst
70cst's Avatar
Also make sure the Panhard Bar is installed properly ... when it isn’t when you get about 50 mph your truck will really feel squirrely ... from a friend
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
