Old 10-03-2021, 11:11 PM   #1
steves1967
steves1967's Avatar
New rims and tires
Its time to ditch the 16.5" wheels on my 71 C-20. Its an 8 lug wheel, so I know I'm a bit limited on wheel selection. I think i'm going to go with the wheel below. I need some help with wheel and tire size- I think an 18x9 will work.
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 10-04-2021, 09:47 AM   #2
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Re: New rims and tires
16.5's are a PITA. I dumped mine.
But your truck looks cool with the steelies and caps. I would keep it the same but with 16's. Same look...Less hassle.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 10-04-2021, 11:36 AM   #3
jocko
jocko's Avatar
Since you asked for help - I can’t imagine anything other than steelies and PO3s on your truck. Just personal opinion. While I have had luck finding 16.5 tires, agree with Paul that 16s are a great option with greater tire selection than 16.5s and nubs to retain the caps. I’m biased, I admit it, but I picture the wheels posted as something more suited to a very custom slammed swb show truck.
Old 10-04-2021, 05:16 PM   #4
Big Kev-O
Big Kev-O's Avatar
Do you plan on changing your ride height? Your truck looks pretty low. There are not many 8 lugs wheels available with enough backspace to keep the tire inside the wheel well. Keep in mind a 18x9 wheel is actually 10 inches wide. You would need at least 5.5" backspacing on the front to keep 18x9s inside the wheel wells and depending on your tire size you still might rub the tire on the outside. Do your tires rub now?
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 10-04-2021, 11:46 PM   #5
steves1967
steves1967's Avatar
I plan on keeping the ride height where it is, nothing rubs now. The truck has 4.11 gears in it. The tires are about 27” tall- which means 3500 rpm is only 70 mph....
Old 10-05-2021, 12:21 AM   #6
Warrens69GMC
Warrens69GMC's Avatar
No, spend the money on 18" Detroit steel wheels, they have the clips for stock
Old 10-05-2021, 08:37 AM   #7
^^^ No 8-lug
I like the 8" steel wheel with caps look. The wheel you show ain't ugly. The question on 9" fitting is about front end clearance of wheel, then tire clearance. If you want the same size tire all around you might end up with a size that looks too small on the rear.
Old 10-05-2021, 08:58 AM   #8
Joesjunk
Joesjunk's Avatar
I’m not sure you are going to get much taller tires on that truck with it sitting so low
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 10-05-2021, 09:28 PM   #9
ItWillBeSlow
ItWillBeSlow's Avatar
^^^ No 8-lug
Detroit Steel does make the Del Ray style (in photo) and the smoothies in 8 lug.
1972 C20
ItWillBeSlow is offline   Reply With Quote
Old 10-06-2021, 01:14 AM   #10
dagnabbitt
dagnabbitt's Avatar
There's not too much I would change about your truck, I love it as it sits. I do support a wider wheel in the back, though, the backspacing on yours is presently a little inward: I would fill up that wheelwell. Truck has great stance and I think it would look great with a 10" wheel in back.
Wheel Vintiques makes just the thing: a stock looking deep dish steel wheel that I think would look great on your truck, especially powdercoated Navajo White. You can keep your dog dishes and also go with a wide street tire.
But if you are leaning towards that modern look, hey its your truck and don't let anyone tell you what to do.
Solve your rpms with an overdrive or taller rear gears, tires are for looks and handling in my opinion, not for mpg.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 10-06-2021, 02:32 AM   #11
Warrens69GMC
^^^ No 8-lug
Says 8x6.5 on the far right of the image I posted
Old 10-09-2021, 12:26 AM   #12
steves1967
steves1967's Avatar
Yep, I'm thinking the DSW Del Ray wheel. 18 x8 front and 18 x9 rear
powder coat them, clean up my hubcaps and it'll look great!
'22 Chevy Tahoe RST
Old 10-09-2021, 12:34 AM   #13
Warrens69GMC
I knew you would make the right decision.
Actually, I want them for my Big10
Old 10-09-2021, 12:41 AM   #14
Warrens69GMC
late 70-ish
