Old 10-05-2021, 05:54 PM   #1
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Steering wheel needed
I am putting in my 65 Suburban a floor shift 69-72 truck column and I need a nice steering wheel to go on top. Thanks in advance!
Clyde65
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-05-2021, 07:01 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Steering wheel needed
i hae a nice 65 steering wheel if youre interested
1967custom
michael bustamante is offline   Reply With Quote
Old 10-06-2021, 07:38 AM   #3
Clyde65
Clyde65's Avatar
I also have one but it won’t work on the column unfortunately.
Or if it does, I haven’t figured out how to put it on there
Clyde65
Rebuild of Clyde
support our troops!
Old 10-06-2021, 08:47 AM   #4
va72longhorn
va72longhorn's Avatar
Is there a specific color you’re looking for? I’ll have nice blue 66-68 wheel as soon as I come across a correct 72 blue wheel.
va72longhorn is offline   Reply With Quote
Old 10-06-2021, 11:30 AM   #5
atog
What year, color, and quality steering wheel are you looking for?
atog is offline   Reply With Quote
Old 10-06-2021, 02:04 PM   #6
Clyde65
Clyde65's Avatar
Column is a 69-72, a saddle or black would be good. Can you paint them?
Clyde65
Rebuild of Clyde
support our troops!
Old 10-06-2021, 10:22 PM   #7
dmjlambert
dmjlambert's Avatar
I suggest open a post in the 67-72 Pickups section with pictures of what you have going on, and get help getting the 65 steering wheel fitment fixed. Even if you don't want to use it, you will probably need to resolve the problem in order to fit a 69-72 steering wheel. You should be able to use early 60's steering wheels on a 69-72 steering column. I have one on mine and it fit like it belongs there.
dmjlambert is offline   Reply With Quote
Old 10-07-2021, 08:42 AM   #8
Clyde65
Clyde65's Avatar
Dmjlambert, did you put the 60-66 turn signal switch and etc in the column? I didn’t think to do that.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-07-2021, 12:15 PM   #9
dmjlambert
dmjlambert's Avatar
I used the turn signal switch, canceling cam, and other components that were already in the 1969 steering column, and just put the early 60s steering wheel on it. It is a direct fit and just works.
Old 10-07-2021, 01:29 PM   #10
Clyde65
Clyde65's Avatar
How did you do the horn button?
Clyde65
Rebuild of Clyde
support our troops!
Old 10-07-2021, 02:31 PM   #11
Clyde65
Clyde65's Avatar
Clyde65
Rebuild of Clyde
support our troops!
Old 10-07-2021, 06:32 PM   #12
dmjlambert
dmjlambert's Avatar
First, remove this plug/contact assembly, you won't be needing it but you do need to use the hole.
Then put the cancelling cam on the steering column.
Then put the steering wheel on and the nut that holds the steering wheel down. The tower and contact of the cancelling cam sticks up through the hole in the steering wheel that was previously occupied by the plug/contact in the first picture. The rest of the horn button assembling happens after the steering wheel is on. Here is a thread with some discussion of assembly.
http://67-72chevytrucks.com/vboard/s...14#post8452614
If you have any trouble with it, I recommend opening a fresh thread in the 67-72 Pickups section with pictures of what you have going on. It will get more attention than this thread in the parts section.
Old 10-08-2021, 02:56 PM   #13
Clyde65
Clyde65's Avatar
Dmjlambert! You are a wonderful man! Thank You for that, that is exactly what I was needing!
Clyde65
Rebuild of Clyde
support our troops!
