Was there a default radio for the 73-78?
Were radios optional on the 73-78?
![]() Join Date: Jun 2016
Re: Was there a default radio for the 73-78?
Not sure on those years, but I have an 84 that has no radio.
Bubba |
What's there instead? A steel blanking plate, or some sort of plastic cover?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
I'm looking at the SPID on a 78 and there is no rpo code listed for the radio. So I assume this meant no radio installed but I'm not sure if there was a default radio with no rpo (perhaps AM only radio).
78 Big10 454
![]() Join Date: Jul 2008
My 1978 was a radio delete.
1978 Chevy SWB C-10 2WD 454/400 |
My 76 has no radio. Just a plastic block off plate.
![]() Join Date: Feb 2000
Standard equipment was no radio- both the AM and AM/FM were regular production options. Trucks with no radio came with a plastic block off plate made to match the dash bezel.
The different trim packages didn't include the radio either- you still had to choose AM or AM/FM. Even the cigar lighter wasn't included in the base trim/standard model trucks. That was included in the next trim above the base model Custom/Custom Deluxe trim levels. https://www.gmheritagecenter.com/gm-...tion-kits.html
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Active Member
![]() Join Date: Jan 2017
When I bought my 1985 K20 new both a radio and heater were an option - same on my 1988 K20 Suburban. I ordered both vehicles rather than buy off the lot at that time.
I would also like an original radio for my 82.
My SPID lists no radio but I have the windshield with built in antenna. Not sure why.
Here’s what a 76 radio block off looks like. It’s fastened from behind through what would be the volume and tuner holes on the gauge surround. And below that is the no cig lighter - mentioned in a post above.
#12 | |
#13 |
#14 |
#15 | |
#16 | |
#17 | |
Otherwise it’s got a MPH speedo, with KmH in smaller blue font, but we didn’t go metric on speed until Labour Day 1977. |
#18 |
Ace easy way is to look at the lower center housing for None A/c your will have three leavers in the housing sticking out, two all most side by side one off by it shelf.
Most times the radio have to be ordered by you. Or if it was ordered by Dealer or a early special order buy. That would be the only radios other option did at the Dealer installed options. Or in some cases they would take easier option out one truck put in your your truck for the sale. As I bet windshield antenna got the radio taken out put in another truck for the sale. Before you got to see the truck with the radio in it at the dealer.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#19 |
The SPID sheets would these have been printed at the factory or at the dealerships? I think they were printed at the factory. So the RPO options that were on the truck is what came from the factory.
#20 |
SPIDs were printed at the assembly plant- not by the dealer. Any dealer add ons or accessories were not printed on the SPID
#21 |
#22 |
Possibly the purchase agreement, invoice, receipt- usually those have the added items on them, prices, etc.
