10-06-2021, 03:46 AM | #1 |
Front axle shaft universal joint upgrade?
Pulled the front axle shaft universal joint from my 71 K5 Blazer and boy were they toast. In finding part numbers for replacement, I came across this information.
Dana Spicer 5-260X - 4x4 Front Axle U-joint. Commonly known as the "Small" axle u-joint. This u-joint was found on early Jeep, Bronco, Chevy, Dodge, International and Ford 4X4 trucks before they realized that it was too small and started to use the larger and stronger 5-297X now the 5-760X Easy to spot on open knuckle front ends by measuring the bearing cap diameter. Utilizes inside "C" Clips to lock u-joint in place. Is there an upgrade that can be one to utilize the later universal joints? |
10-06-2021, 07:47 AM | #2 |
Re: Front axle shaft universal joint upgrade?
If you want to run the larger 760 joints then you'll have to get new shafts for the larger u-joints- whether you get aftermarket or used shafts from ~'73 and newer Dana 44 axles. There is no conversion joint or way to adapt a 260 shaft to accommodate the larger 760 joint.
http://67-72chevytrucks.com/vboard/s...d.php?t=804777
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com Last edited by MJN; 10-06-2021 at 03:30 PM. |
10-06-2021, 06:19 PM | #3 | |
