It's in an '84 c10 but after some research it's not stock. Does anyone know what year it is out of?
Power Windows/Locks Ac/Heat Duel Tanks This wiring harness has all these options, and the truck has dual tanks.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Re: Can Anyone Identify This Fuse Block
As always any help is greatly appreciated! Thanks for your time.
81- up but you got lots of leads on that fuse box. may be off large van or truck tow truck boom truck it only look like 3 are not live pined you have lots of option but I think the signal is not there or it at the top right. It hard make out all marking that good.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Does your truck have A/C is it a NONE A/c truck. I does have a choke carb so it 81-86.
#5 | |
For comparison, this one is from a '92 G20.
| Bookmarks |
