Old 10-07-2021, 06:25 PM   #1
MDFarms
Rear axle question
Good evening, I have a 1972 k10 that had a 3.07 ratio want to switch to 3:73 ANYONE KNOW IF THIS WOULD BE TYPE 3 OR 4 CARRIER WITH ORIGINAL 3:07 RATIO? I NEED TO FIGURE OUT CARRIER INFO FOR ORDERING PARTS
STAMPED GM 56 ON ONE SIDE OF HOUSING
MDFarms is offline   Reply With Quote
Old 10-07-2021, 06:42 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rear axle question
Ratio should be stamped on the metal tag fastened to the top bolt. If it only has the tooth combination stamped on it go to the red chart in post #2 in this thread to look it up.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
I can't help you on the series.
LockDoc
Leon
Old 10-07-2021, 07:18 PM   #3
Bigdav160
Bigdav160's Avatar
K10? Are you changing the front gear too? Figure the need another differential case
Your 3.08 is a 3 series and the 3.73 is a 4 series.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-07-2021, 08:05 PM   #4
HO455
Post Whore
HO455's Avatar
The 3.08 gears are on a 3 series carrier from the factory. If you want to go to 3.73's on the 3 series carrier you can use a "Thick" gear set. That is what I did with my Burban.
Do you currently have a posi?
https://americanpowertrain.com/shop/...-a-3-73-ratio/
https://www.differentials.com/techni...arrier-breaks/
RIP Bob Parks.
Old 10-07-2021, 09:05 PM   #5
MDFarms
the tag said 3.07 i believe and its all correct for year as the date is on ring gears. Yes switching both from 3.07 to 3.73 frnt is a Dana 44.
I thought 3.73 is a series?type 3? I see I have two different opinions here so far.
Old 10-07-2021, 09:21 PM   #6
kwmech
Do not go by the tag after 40 years, look at the gears and get numbers off of those. You can use the same carrier in the front
Old 10-07-2021, 09:48 PM   #7
CMars45000
CMars45000's Avatar
Correct. The carrier "split" on the 12-bolt is at 3.73. 3.73 and numerically higher are 4-series. But they do make "thick" gear sets that would allow you to use your 3-series carrier, if it was in decent shape.
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 10-07-2021, 10:34 PM   #8
HO455
Post Whore
HO455's Avatar
Sorry I didn't make my point very well. The factory carrier for a 12 bolt truck axle with 3.73 gears would be a 4 series carrier. As stated above.
I wanted to point out that there was a way to go to 3.73's without having to get a new carrier for the rear axle. See the first link I posted above.
Fortunately for you the Dana 44 carrier is 3.73 and down so you can use your current carrier for the new 3.73's. See the second link I posted.
RIP Bob Parks.
Old 10-08-2021, 06:15 AM   #9
ohboy321
ohboy321's Avatar
You may want to pull the cover to be sure. I thought I had a standard 3.07 axle because of the "spin the wheel" test, but was surprised to find it was a posi when I took the cover off. The clutch plates from one side fell out when I pulled the cover. I installed a new clutch kit and all is well.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 10-08-2021, 07:57 AM   #10
MDFarms
Oddly enough my gears on front and rear along with carriers look like new, meaning not smooth and shiny but still look like new condition. I don't think this truck was used very hard other than a daily driver. It was originally a step side so I don't believe it hauled much in bed. Not sure about trailers and such though. Tough to have a short bed stepside as a work truck.
So.it seems I need wide gear set for my carrier. I had cover off and it was not a diff lock unit. Wouldn't mind one though.
Old 10-08-2021, 08:03 AM   #11
MDFarms
Anyone have a good 3.73 posi lock carrier for a GM 12 bolt rear-end they would wanna part with?
Old 10-08-2021, 08:58 AM   #12
burnin oil
Depending how you use the truck I would suggest a detroit locker in the rear. Posi rears will lock in after approx 1.5 tire rotations to push you forward but if there is to much torque applied to one wheel they will disengage. Street use is not a big deal but off road it becomes apparent. Pulling a hill on loose gravel is enough for the tire to unlock. I would also not use a govlock type limited slip. They act the same but tend to unlock when you feather the gas. Detroit keep both rears locked together under normal driving and then unlock the tire for turning. I have all 3 types of these units and my gravel driveway let's you know quickly how well each type work.
We have a jeep that we use for the driveway since the 2wd vehicles usually can't make it up the hill. The rear-end was swapped to the ford explorer axle with a factory limited slip. I rebuilt it with the mustang clutches that are stronger and that rear has some odd behaviors. You can feel it lock in all the time and gives a push feeling to the jeep. It tends to get you going at a slight angle. The Detroits don't give me that since they were already pushing the truck forward. Just food for thought since regearing is expensive and you want to get it right the first time.
burnin oil is offline   Reply With Quote
Old 10-08-2021, 08:28 PM   #13
60case
I just switched from 3.73 to 3.07 I have 3.73 dana 44 gears and 3.73 12 bolt gears and open carrier if you are interested
60case is offline   Reply With Quote
Old 10-08-2021, 08:45 PM   #14
MDFarms
Could you send me some pics? How did gears look? Mine seriously looked amazing but too high for 35's
Old 10-08-2021, 08:47 PM   #15
MDFarms
Sent you a pm requesting pics
Old 10-08-2021, 09:07 PM   #16
60case
I will get some pictures on Saturday
Old 10-09-2021, 09:12 AM   #17
burnin oil
What do you want pics of?
Old 10-09-2021, 10:05 AM   #18
MDFarms
wrong guy sorry
