10-08-2021, 02:24 AM | #1 |
What could these hoses be for?
There are these hoses running underneath the Blazer, one end is not attached, rear of driver's side, and then goes into fitting and then works across to the other side, where it disappears above frame, so can't see what it goes to.
Any ideas what it could be for? The truck was used for camping I believe. |
10-08-2021, 02:34 AM | #2 |
Re: What could these hoses be for?
Augsilery spelling fuel tank or part of the evaporation system , but my guess is on the extra tank, does it have a switch by the drivers side floorboard
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-08-2021, 03:03 AM | #3 | |
Does anyone have a pic of switch I could be looking for? |
10-08-2021, 06:25 AM | #4 |
Here is a thread with some pictures and info.
Link: https://67-72chevytrucks.com/vboard/...el+tank+switch
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
10-12-2021, 01:52 AM | #5 | |
Found the switch on the riser between front floor and rear floor Unable to get in to truck as is on a 2 post hoist, but thinking this toggle switch on bottom of dash might be for switching feed for fuel gauge The only place I think auxiliary tank was mounted was in rear of cabin, with hose going through hole in floor. Again couldn't gain acess to see if there are signs of mounting under carpet So will have a further poke around when I get truck back, but will probably leave alone and redo fuel lines when we remove body. If anyone has seen a system like this one, let me know |
