Old 10-08-2021, 01:52 PM   #1
jeff74
Guest
Posts: n/a
Heater box removal - look away
Finally time to remove the mouse playground..
I realized the bolts and clip nuts for the inner fender weren't going to cooperate, so some of you may want to look away at this point. I drilled a 1" access hole to get the most outboard bolt out. The next one inboard I was able to get with an offset wrench 1/12 of a turn at a time...that stud is long
Pay no attention to those other smaller holes, they're for something unrelated :p
I figured I'd be able to find a plastic plug for that hole and the little ones I'll weld up. The heater core actually wasn't leaking, the fan motor works, and the squirrel cage definitely had a squirrel chewing on it. Super!
Old 10-08-2021, 02:27 PM   #2
BAD1916
Re: Heater box removal - look away
Mine has holes drilled for access as well. This is a feature that should have been done originally. It’s stuff like this that you realize the ones who design aren’t the ones who have to work on them.
BAD1916 is offline   Reply With Quote
Old 10-08-2021, 03:52 PM   #3
BigBird05
Those J nuts weren't designed to last 50 years.
BigBird05 is offline   Reply With Quote
Old 10-08-2021, 04:16 PM   #4
jeff74
Guest
Posts: n/a
For sure. I may drill a hole for the next inboard one as well, but I'll do my best to hit it on the first try. I'll, at least, cut that stud down a bit.
Old 10-08-2021, 04:18 PM   #5
jeff74
Guest
Posts: n/a
Yeah, I hit the ones I could with pb blaster. Got one bolt out, then 2 just wanted to spin the nut. Plan B.
Old 10-08-2021, 09:07 PM   #6
dmjlambert
dmjlambert's Avatar
I was able to get to all spinning nuts but one with vise grips or pliers. I used an impact wrench on the bolt while holding the nut. On the one where I could not reach the nut I used a hacksaw blade wrapped with a rag for a handle, and inserted the blade between the inner and outer fenders and sawed the bolt.
dmjlambert is offline   Reply With Quote
