Old 10-09-2021, 08:06 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
A/T pedal assembly differences from M/T.
So my truck was once a column shifter but the previous owner (my uncle) changed it to a
T-400 A/T. If I was to just remove the clutch pedal and whatever it moves upon, will the brake pedal be fine or does the brake pedal need the clutch attachment?? Hope that made sence?? Thanks
desert-rat is offline   Reply With Quote
Old 10-09-2021, 08:45 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: A/T pedal assembly differences from M/T.
You should be good to go by just putting in spacers for any gaps that removing the clutch pedal stuff leaves. If you're not in a hurry, maybe look at the wtb/wts ads and see if you can make a swap with someone going the other way.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-09-2021, 09:33 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
No need to buy another pedal setup. They are the same brake pedal assembly, mt vs at. The clutch pedal is the only difference. Pull the clutch pedal out and run it. No spacers or anything else needed.
Tyler
57taskforce is offline   Reply With Quote
Old 10-09-2021, 10:44 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Exactly, the clutch pedal runs though the brake pedal, slide clutch out and your done
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
