Old 10-11-2021, 11:07 AM   #1
Dan-K
Blueprint heads
I ended up ordering a set of Blueprint H8002K heads for my truck . After doing some research I was told that I will need to use Adjustable guide plates and ARP head bolts with the smaller size head for clearance issues . Does anyone have experience with these heads and maybe a part # for the head bolts as I am not sure which ones to use .
Dan-K is offline   Reply With Quote
Old 10-11-2021, 07:32 PM   #2
Rickysnickers
Re: Blueprint heads
I have them on the Blueprint engine in my truck. I can tell you they did not use ARP head bolts, so I don't know where that info is coming from. I recently changed my valve cover gaskets, but I cannot remember if there are adjustable guide plates on my heads, sorry.
Old 10-14-2021, 06:32 PM   #3
HO455
Post Whore
HO455's Avatar
Re: Blueprint heads
Have you contacted the folks at Blueprinted as to what they recommend?
RIP Bob Parks.
Old 10-15-2021, 08:16 AM   #4
biketopia
Re: Blueprint heads
My blue print engine has adjustable guides and non ARP hardware. But like stated, give BP a call, they have always been super helpful when I called them.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
