Old 10-12-2021, 03:57 PM   #1
Lethal Tendencies
Lethal Tendencies's Avatar
Spark plug wires with ram horns
What style and how are you guys with ram horn exhaust manifolds running your wires ?
Lethal Tendencies is offline   Reply With Quote
Old 10-12-2021, 04:09 PM   #2
CastIron
CastIron's Avatar
Re: Spark plug wires with ram horns
I have a HEI distributor with ram horns and just went to the local parts store and got wires for a 1975 Corvette. They fit pretty well in the factory location.
CastIron is offline   Reply With Quote
Old 10-12-2021, 04:33 PM   #3
geunther
geunther's Avatar
Using the factory length, down and around he back of the block, along the sides, up through the motor mounts for the front 4 cylinders,
geunther is offline   Reply With Quote
Old 10-12-2021, 04:54 PM   #4
67C10Step
67C10Step's Avatar
This is exactly what I did when I swapped to HEI.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-12-2021, 05:15 PM   #5
FirstOwner69
FirstOwner69's Avatar
Pictures of my 350 with Vortec heads, HEI and 1975 Vette wires run as original.
Jim
FirstOwner69 is offline   Reply With Quote
Old 10-12-2021, 06:01 PM   #6
Grumpy old man
Grumpy old man's Avatar
Vette wires .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-12-2021, 07:47 PM   #7
truckster
truckster's Avatar
Pretty much the same. I used Taylor wires for a 1976 Corvette.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-12-2021, 09:24 PM   #8
Lee H
Lee H's Avatar
I’ve used the vette wires/routing with ram horns on numerous vehicles, they work well. The last 15 years or so I’ve been buying bulk wire, ends, boots and making my own. You get a custom set with each wire the correct length routed the way you want. And when you get a burnt wire or boot your only minutes from a new wire. Little expensive out of the gate. The key to making your own is the stripper/crimper, don’t cheap out if you that route. Good luck, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-13-2021, 12:08 AM   #9
geunther
geunther's Avatar
I noticed everyone keeps stating vette wires. Isn't this the way they were ran from the factory on our trucks? Only asking that it wasn't a corvette only thing? Or saying that to get the correct length?
Old 10-13-2021, 08:29 AM   #10
Grumpy old man
Our trucks didn't come equipped with HEI distributors so there are no "stock HEI" truck wires available . Hence using the later model HEI "Vette" wires .
More HEI install info . https://67-72chevytrucks.com/vboard/...d.php?t=708975
Old 10-13-2021, 09:32 AM   #11
geunther
geunther's Avatar
Gotcha. I know there was no HEI, I was more talking about the routing vs type, Thanks
Old 10-13-2021, 10:58 AM   #12
Lethal Tendencies
Well that helps out alot. Mine on the truck now are way long too long. so I guess I will get some for a vette.
Old 10-13-2021, 11:09 AM   #13
geunther
geunther's Avatar
Running wires like in the pics (stock and corvette routing) will take a longer wire than you usually get at the box parts stores (which people usually run over the tops of valve covers).
Old 10-13-2021, 03:09 PM   #14
cj847
cj847's Avatar
That doesn't make sense...
I don't remember which set of Taylor wires I ordered (may have been corvette or may not have been). BUT I do remember that they were one of the longest custom sets available. ie.....the longest set you could buy with the ends already attached should work pretty well.
Here is the chart with the length of each wire. Note that some are coil and some are HEI, so be sure to double check before ordering. I ordered mine off of Amazon after getting the number from the Taylor website.
https://www.taylorvertex.com/Product...uyersGuide.pdf
cj847 is offline   Reply With Quote
Old 10-13-2021, 03:21 PM   #15
pwdcougar
pwdcougar's Avatar
Which part number did you get and have you installed them yet?
Taylor lists several part numbers. This is copied from the pdf
64617 V8 Corvette 75-82 350, 400 HEI 22 26 28 28 44 46 56 56 NR
74X17 Chevy/GMC Trucks 50-60 Series 90 90 90 90 90 90 90 90
80617 77-82 350, 84 350, 89 350M
84X17
91017
51017
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 10-13-2021, 03:38 PM   #16
697498chevy
Been 7 years ago , but I bought a set of ign wires at NAPA that fit my '69 307 well . MPW 2821 . HTH
697498chevy is offline   Reply With Quote
Old 10-15-2021, 03:48 PM   #17
pwdcougar
pwdcougar's Avatar
Where can I get the brackets circled in the pictures? Haven't had any luck in my searches.
Old 10-15-2021, 03:57 PM   #18
roboticjunky
This quote was in an older thread.
Originally Posted by ray_mcavoy View Post
The 2-wire Corvette ones look the same as the ones used on these trucks. But the 4-wire ones that go on the back of the block are different.
These ones from Classic Parts of America appear to be correct:
4-wire holders for bellhousing area of block: http://www.classicparts.com/1958-69-...ctinfo/83-386/
2-wire holders (these attach using the same bolts that hold the heat shields) http://www.classicparts.com/1958-72-...ctinfo/83-387/
And if you don't already have them, these are the head shields that were used with the rams horn manifolds: http://www.classicparts.com/1957-72-...ctinfo/83-389/
The original spark plug wire routing also used a couple of these clips (one on each side) to hold the wires down near the oil pan rail. They attach using the existing oil pan bolts: http://www.classicparts.com/1958-72-...ctinfo/83-388/
There were also a couple of 4-wire holders that attached to the engine using the rear corner intake manifold bolts. I don't think I've ever seen a reproduction of the driver side one. But there is a reproduction of the somewhat similar looking holder used on some cars ... it attaches to a valve cover bolt instead and looks like this: http://www.parts123.com/parts123/yb....2a~Z5Z5Z5AAGRQ
On the passenger side, this style of bracket was used with manual transmissions:http://www.parts123.com/parts123/yb....5AAHNM~Z5Z5Z53
I think automatics had the pass side plug wire holder spot welded to the dipstick tube (at least cars did anyway ... not sure about trucks).
roboticjunky is offline   Reply With Quote
Old 10-15-2021, 04:45 PM   #19
pwdcougar
pwdcougar's Avatar
Thanks!
Old 10-16-2021, 09:23 AM   #20
Zeroman
Zeroman's Avatar
I am running Corvette rams horn manifolds on my 350. I used 2 right side manifolds - both point straight down.
I used after market wire looms mounted above the manifolds instead of routing below the manifolds.
My truck is no where near stock, so it does not bother me to use something different.
Zeroman is offline   Reply With Quote
Old 10-16-2021, 12:15 PM   #21
Boog
laying low
Boog's Avatar
Zeroman. I want to run my wires above the ram horns too and want straight plug wire terminals like yours. I see you used MSD wires. If you don't mind, what part number and application are those?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-16-2021, 05:44 PM   #22
geunther
geunther's Avatar
I found my receipt from when I ordered a set from Lectric Limited. They fit well and I have not had any issues. They are the length for stock routing.
PN#: 1250-999
