Old 10-13-2021, 06:20 PM   #1
Ironhorse
Ironhorse's Avatar
Pair Solid Mirror Elbows
PRICE REDUCED
Have a pair of solid steel chromed mirror elbows. Arms measure 7 1/2'' on long end and 5 1/2'' on the short end. These were in a box or mirror parts I got some time back. The studs must have rusted and broken off since all studs are gone. Both arms have been marked and center punched ready to drill for threaded bolts. One arm end has been started to be drilled for a threaded bolt. I don't have a floor drill press and since don't need these for my truck they're offered here. Can be used with a bolt for mirror mounting or if you have the correct acorn nuts use an all thread rod epoxied in and then the acorn cap. Set to go with no more rust thru on your mirror arms. $20 shipped for the pair, money order or $$, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-15-2021, 10:42 AM   #2
Ironhorse
Ironhorse's Avatar
Re: Pair Solid Mirror Elbows
Solid arms for mirror support, drill them your self or have them drilled and never worry again about rust thru and at a lower cost than cheap overseas imports if you can even get them.
Wellington, Ks
Old 10-18-2021, 09:01 PM   #3
Ironhorse
Ironhorse's Avatar
Drill these or have them drilled, guaranteed they won't rust thru like the aftermarket el Cheapo hollow tube mirror arms.
Wellington, Ks
Old 10-21-2021, 07:42 AM   #4
Ironhorse
Ironhorse's Avatar
TTT with REDUCED PRICE $20 shipped, money order, do not have Paypal.
Wellington, Ks
