Old 12-26-2003, 10:36 PM   #1
Frank-id
Any one know where on the net
GM part numbers can be found. My son in law is restoring a '69 Camaro. While gathering some 4 speed parts, the bell housings does fit the engine, while using Chevy parts. The clutch/pressure plate assembly will not allow the bell housing to be bolted onto engine. He has found 3 aluminium housings and none will fit. The engine is a 350 sb and plans to use a muncie 4 gear, all factory parts. Are there different bell housings for small block engines. The p-plate is the 11 inch style.
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
Old 12-27-2003, 12:51 PM   #2
Txstruck
Txstruck's Avatar
http://www.car-parts-place.com/p36-3...-listings.html
[url]http://www.firstgen.com/Rick'sFreeCamaroPartsCatalog.html[url]
Hope these help you out.
Steve
86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud"
Txstruck is offline   Reply With Quote
Old 12-28-2003, 05:58 AM   #3
jimfulco
The housing for the big (14") flywheel has a part number cast on the right side that ends in -621 (I think it's 3899621). The smaller one for the 12.75" flywheel has pn 3858403. Here's two places to try:
http://www.rickscamaros.com/cgi-loca...784+1073508719 (click on "bellhousing & cover")
www.kajunjon.com
jimfulco is offline   Reply With Quote
