10-17-2021, 10:30 AM | #1 |
C-20 Master Cylinder leaking
Morning Guys I've got a 72 C-20 daily driver I brought back from the grave every time I run this truck my brake fluid leaks out of the cover on the master cylinder I've replaced the gasket twice how can I fix this problem? It's lookes like it's not level? Thanks Saddletramp
10-17-2021, 01:07 PM | #2 |
20' Daredevil (Ret)
Re: C-20 Master Cylinder leaking
I had a similar issue once..... my memory isn't helping much but I think it had to do with the cap not sitting down all the way. Seems like it took some minor trimming to get it to seal properly.
Sorry I'm not more help, with any luck someone else will jump in here.
10-17-2021, 01:52 PM | #3 |
I had a similar problem and ended up re-arcing the wire retention hoops to load the cap tighter.
10-17-2021, 06:17 PM | #4 |
Thanks for the response guys I'll tweet the arms that hold it down .saddle tramp
10-18-2021, 11:32 AM | #5 |
Topic discussed in this thread as well. http://67-72chevytrucks.com/vboard/s...d.php?t=809178
10-18-2021, 11:53 AM | #6 |
Morning Thanks for the info I'm going out to my Truck to see what I can do appreciate it.saddletramp
