12-26-2003, 11:30 PM | #1 |
Sleep-Deprived
73-78 PS Gear Box Instead of 67-72?
I'm looking at buying a power steering gear box very soon -
possibly tomorrow - and wanted to find out if any of you all are using one instead of the 67-72 boxes. I understand that the later box is a faster ratio (?) I've read up in the search and have seen mention of retaining the 73-87 external reservior - which confused me. My pump has its own reservior. I'll be using a power steering pump from a ~69 292 and lines for a 67-8 350 equipt c/10. The gear box will be from a 74 or 75, or maybe I'll shop around some more on price. Does this sound kosher? Any suggests are welcome. Thanks to Frank at Pick-M-Ups for the ps pump, the quick shipment and the insightful knowledge. He even blasted and painted it! |
12-27-2003, 12:46 AM | #2 |
Careful, they attack...
Shoudl work fine, the newer boxes had the faster ratio and I think some (or all) were variable also. The set up you describe should work out ok.
12-27-2003, 01:10 AM | #3 |
Like jmanz69 said. 79 or later won't work without reworking the line fittings. Metric threads. The remote reservoir was used with pumps that didn't have a integral reservoir. I think big block engines used this set-up.
-Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
12-27-2003, 01:39 AM | #4 |
im not all together sure about all of this i used my stock gear box and a 86 chevy van pump and my lines to the stock 72 and everything works great
72 cst 2wd blazer sb soon to have tilt manual 72 gmc swb fleet 2wd bb air tilt auto 93 c/3500 crew-cab dually 03 chevy suburban LT quadrasteer c/2500 4x4 |
12-27-2003, 02:00 AM | #5 |
Sleep-Deprived
This could turn into a project that takes
several weeks instead of a weekend. I'm refurb'ing the steering column at the same time, so it could take longer than I'd hoped. As long as I get the right parts to start with, that's the main thing. The faster steering ratio, combined with the power steering is the main objective tho. So if anyone sees any red flags, please speak up. Thanks for the confirming replies so far. BTW, a used steering gear for $75 (+tax) sound reasonable? I might try a u-pull-it place for a lower price.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
12-27-2003, 02:04 AM | #6 |
Just like to part out trucks!!
I got used one for $40 plus shipping
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-27-2003, 02:19 AM | #7 |
I put the later box in my truck. Seems like it's 3 1/2 turns lock to lock instead of 4 1/2 turns. I just unscrewed the pressure fitting from the newer p/s pump and put it in my old pump. The return line just uses a hose on a nipple. This is a BB w/remote reservoir.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi. |
12-27-2003, 02:39 AM | #8 |
To be on the safe side, take your lines with you and try them on the new/used box. Good luck!
-Sam
12-27-2003, 11:13 AM | #9 |
Sleep-Deprived
Around $40 is what I was hoping for, teeitup. I've
looked on ebay, but the boxes currently listed are as much as local and they're not the year I'm looking for. Jeff, 3 1/2 turns compared to 4 1/2 is what I'd heard. I thought this would be more popular of an upgrade than the amount of responses I've gotten, and there wasn't much info when I searched either. I swear when turning a corner, when my steering wheel spins back to center it puts off more air than an osilating fan with the original gear box. Not to mention how ssssccccchhhhhllllllllooooowwww I have to go when I'm making the turn.
