Old 12-27-2003, 12:51 AM   #1
clipity
Big hands Big feet ohwell
clipity's Avatar
hopping in reverse
Ok here is the problem im having.When in reverse, backing up and turning the wheel my 89 suburban 4x4 it seems to hop.It also happens going forward and turning some times.Sharp turns.Any ideas would be greatful.
Thanks Derreck
I only drive as fast as I can see!!!
89 Suburban 4x4
49 Willys flatbed 4x4
87 Banshee
88 Katana 1100
clipity is offline   Reply With Quote
Old 12-27-2003, 01:01 AM   #2
Sweet72
Sweet72's Avatar
Do you have a limited slip (posi) rear? Which wheel is hopping?
-Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-27-2003, 01:08 AM   #3
clipity
clipity's Avatar
Not sure just bought the rig a few weeks ago and realy havent had time to check it out.I thought it might be caused by a locker to but like I said havent had the time to find out.
89 Suburban 4x4
87 Banshee
88 Katana 1100
