Old 10-20-2021, 07:55 PM   #1
Graham57a
Graham57a's Avatar
Correct Wheel Cylinder for a 72 K20 w/ a H052??
Very specific question here but has anyone replaced the wheel cylinders in an H052 and have a good part number handy? I’ve ordered from 3 places now and they are all wrong. The picture below is the original cylinder compared to what rock auto sent me. I also tried the parts house and they couldn’t even order something for me. Truck is currently out of commission until I get this fixed so some help would be greatly appreciated!
Graham57a is offline   Reply With Quote
Old 10-20-2021, 08:50 PM   #2
burnin oil
Re: Correct Wheel Cylinder for a 72 K20 w/ a H052??
Measure the bore size of the cylinders. If they are the same size, you shouldd be good to go other than tweaking the brake line for the different angle. The parts stores stock a single casting for multiple applications. The dually cylinders cover about 40 years and multiple axles and brands and I bet the SRW are the same. If you are stuck on originality get a rebuild kit and hone the wheel cylinders out.
burnin oil is offline   Reply With Quote
Old 10-20-2021, 09:39 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Got these from Napa back in 2012 -- the numbers are still on the site so should still be good. We put these on my '72 K20 with HO52.
Right rear #UP37039
Left rear #UP37040
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-20-2021, 09:56 PM   #4
cangim
Through autozone and some coaching on how to search we found these for my HO72.
1972 C30 2WD 157” WB
cangim is offline   Reply With Quote
Old 10-20-2021, 10:04 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You have examples for a coil not leaf spring rear. Here are examples of what I believe are correct.
Old 10-20-2021, 10:40 PM   #6
Graham57a
Graham57a's Avatar
Thanks guys! I ordered the ones from napa, they should be here Monday. Fingers crossed! I really appreciate the quick input
Old 10-20-2021, 10:42 PM   #7
Graham57a
Graham57a's Avatar
I thought that might be the case but the examples I kept finding looked correct when shown for coil springs and the three that I actually ordered were tagged for leaf springs. This is a pic of what rock auto says is correct for coils and it looks like what I need.
Old 10-20-2021, 11:03 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet. Keep us posted and if you can confirm any other part numbers like drums etc you might make use of please share.
Old 10-21-2021, 07:03 AM   #9
Coil spring have angled line/bleeder and leaf spring are straight
Old 10-21-2021, 10:16 AM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The one pulled from the leaf spring rear of his k20 and posted above is angled though.
Old 10-21-2021, 10:27 AM   #11
chevmn
If you have not purchased rear shoes........
https://67-72chevytrucks.com/vboard/...d.php?t=822013
chevmn is offline   Reply With Quote
Old 02-03-2022, 10:51 AM   #12
MJN
MJN's Avatar
Not sure if you found the wheel cylinders you were looking for but The Filling Station has these that look like they match your original.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-03-2022, 12:47 PM   #13
Graham57a
Graham57a's Avatar
Yes I did, the unit from Napa ended up being correct. Thanks for following up
