Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-20-2021, 11:54 PM   #1
Asshat
Asshat's Avatar
Parking brake calipers- Wilwood
Anyone ever use these?
Are they intended to lock on the wheel rotor?
https://www.summitracing.com/parts/wil-120-12069-rd
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 10-21-2021, 10:38 AM   #2
truckin 79
Re: Parking brake calipers- Wilwood
Those look similiar to the calipers on the rear of my 79 Trans Am. They are a screw in style of piston for the emergency brake. The piston works with hydraulic pressure during normal braking. When applying the parking brake there is a threaded screw in the back of caliper piston that attaches to that arm It puts manual pressure against the rotor to keep it from moving.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 10-21-2021, 03:17 PM   #3
Asshat
Asshat's Avatar
I already have the Eldorado style hydraulic/mechanical calipers.
I'm wondering if anyone makes a mechanical caliper just for parking brake applications. It looks like that is the one I linked from Wilwood. I will have to call them and check.
292, 4-speed
Old 10-22-2021, 08:39 AM   #4
biketopia
Yes, the link you posted from wilwood is exactly as you describe, a cable operated mechanical disc brake, typically used for a parking brake.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is online now   Reply With Quote
