10-21-2021, 07:04 AM | #1 |
'68 Turn Signal Half Moon Connector Location
Hi all, another hopefully quick question here (again, did both a Google and Forum search and didn't come up with the info I was looking for).
I am in the middle of replacing the main under dash harness on my '68 GMC. Purchased the factory correct harness for '67-'68s from AAW, been a breeze really. Man was my old, original harness in terrible shape from years of PO abuse (and even me just making things work for the time being when I got the truck over 10 years ago). Now my question is this; does the turn signal switch half moon connector mount/clip somewhere under the dash (it looks as if it does have a slide in clip in the middle on the top of it) or does it just free hang back here behind the gauge panel?
10-21-2021, 11:03 AM | #2 |
The Older Generation
Re: '68 Turn Signal Half Moon Connector Location
I have never seen one that was actually clipped to anything under there. LockDoc
10-21-2021, 11:27 AM | #3 |
should sit on top of the column.
10-21-2021, 11:36 AM | #4 |
That is the connector for the steering column wires other end should be coming out of the column, if yours is factory that is. Most of mine free hung, unless I zip-tied the bundle up some.
10-21-2021, 11:41 AM | #5 |
That's what I thought as well given the shape of it but there is absolutely no way, it's much too short to reach the column and be connected to the light and wiper switches. My old harness wouldn't have been able to sit there either. AAW prides themselves on being very true to the factory specs and from everything I've seen from them so far (this harness as well as a new engine and front lighting harness under the hood) they've been spot on.
10-21-2021, 11:45 AM | #6 | |
Was just curious if it the connector just hung freely or clipped in place somewhere was all. As another member mentioned, it looks like it should sit on the column given it's shape but there is no way it would reach. Thanks!
10-21-2021, 11:46 AM | #7 |
I believe it should be hanging from that metal tab that's on the firewall directly above the speedometer cable. You have your main cable bundle hanging from it, but I believe the main cable bundle is supposed to be attached to similar tabs on the rear of the dashboard above the gauge panel.
10-21-2021, 11:48 AM | #8 |
Nice! I'll take a look at that this evening or tomorrow when I get the chance! Thanks and thanks for the pic!
10-21-2021, 11:52 AM | #9 |
I modified my response above based on your photo.
10-21-2021, 11:54 AM | #10 |
Hmmm, interesting. I'll check into that too. Thanks!
10-21-2021, 12:17 PM | #11 |
Here's a better photo that shows one of the other tabs up above the gauge cluster where the main bundle is routed.
10-22-2021, 06:16 AM | #12 |
Good call on this pjmoreland! I rearranged my harness like how your picture shows and I think it will work out nicely. Puts less stress on the wiper switch wires too.
10-22-2021, 10:38 AM | #13 |
10-29-2021, 07:03 AM | #14 | |
Thanks!
10-29-2021, 10:59 AM | #15 |
I have it running through the small space above and to the left of the column just behind the gauge cluster. Mine doesn't have a straight connector with an adapter on it though, so I can just barely wiggle the curved connector through that opening with the column and gauge cluster in place. You might have to do some partial disassembly to get that larger connector through.
10-29-2021, 11:51 AM | #16 | |
10-29-2021, 11:57 AM | #17 |
You can see the wires coming through the little opening in this photo.
11-01-2021, 06:13 PM | #18 |
Here's a photo of mine taken through the I/P hole before I removed it from the cab to recreate/replace the dash harness. The clamp is on a metal flange behind the dash face to the left of the steering column.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
11-02-2021, 06:17 AM | #19 | |
Also.... I'm trying to orient your pictures and description in my head; in your second picture on the upper right, is that your steering column with the white band around it? Are we basically looking to the left of the column, through the dash where the instrument panel would be, the dark area behind the wires being your cab floor/wall?
11-02-2021, 10:45 AM | #20 | |
These pictures are both of the bottom left corner of the I/P opening in the dash.
11-02-2021, 06:46 PM | #21 | |
Also a shot of the harness side connector which has the clip.
11-02-2021, 06:49 PM | #22 |
Does your truck have a bendable metal hold down like is shown in post #14 on the firewall? It should be directly above the speedometer cable.
11-02-2021, 07:12 PM | #23 | |
Also the 1970 fuse block is mounted up and down, not right and left also because of the change in parking brake from lever to pedal.
11-03-2021, 06:31 AM | #24 | |
They may very well be routed differently from 67-68 and 69-72 because of the hand brake / fuse panel direction situation.
11-09-2021, 02:16 PM | #25 |
Wow, this has piqued my interest. I found this thread on it as well. https://www.67-72chevytrucks.com/vbo...d.php?t=783502
I wonder if these clips are reproduced?
72 C10 lwb fleetside -stock 350/350 combo |
