Old 10-22-2021, 07:22 AM   #1
65truckowner
65truckowner's Avatar
1965 c10 sleeper
Has anyone built a sleeper 64-66 c10? I am thinking about a field fresh swb with skinny tires then a 454 under the hood.
65truckowner is offline   Reply With Quote
Old 10-22-2021, 09:25 AM   #2
60-66
60-66's Avatar
Re: 1965 c10 sleeper
How about a 63 , New Mexico field truck. 454 with lots of good parts TH400 3:73 posi
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-22-2021, 09:33 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep. That'd do it.
Old 10-22-2021, 11:15 AM   #4
AcampoDave
AcampoDave's Avatar
I kind of went that route, but I kept my original 283 engine. I gave it the usual goodies to wake it up including 416 heads from a 305 and focused on improving its street torque, I also added a Muncie 4 speed and kept the exhaust note very subdued. The interior looks like a hot rod while the exterior looks mostly stock. Some regard a 283 as weak, but mine is plenty enough for me and the 15 mpgs are pretty decent. It's a blast to bang it thru the gears at wide open too.
AcampoDave is offline   Reply With Quote
Old 10-22-2021, 02:25 PM   #5
bnorth
I am a big sleeper fan however the benchmark of 'fast' has been raised a lot in the last 10 years. It better be a pretty stout 454 to keep up in the day and age of ls turbos being swapped into everything under the sun.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 10-22-2021, 04:28 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
I went with 462 ci of Pontiac that made 528 bhp before 5K RPM and 500 ft-lb off idle on 87 octane.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-22-2021, 05:15 PM   #7
65truckowner
Yes just what I was looking for. I love the 283 engine I have one in my 67 impala ss and an extra in my shop floor
Old 10-22-2021, 07:15 PM   #8
AcampoDave
AcampoDave's Avatar
My truck has been a blast. Fun to drive hard, a pleasure to drive gently, and I drive it all over the place too.
If you want to know anything else about it just just ask.
Old 10-22-2021, 08:01 PM   #9
65truckowner
Go to youtube and type in 9000 rpm 283 launch and you can see how weak they are
