Old 10-24-2021, 09:02 PM   #1
Backpayne
Need help with some redneck engineering
Finally got my '64 on the road after a few years and noticed some vibration when first moving forward. I knew exactly what it was and realized I'd forgotten to address it. One of the previous owners swapped in a different, I assume, 2-piece drive shaft and "engineered" a horrible mount for the carrier bearing support. See the pictures for this abomination. 🤦*♂️ If they would have used angle iron it may have worked, but the flat steel bar just flexes up and down.
I'm trying to work with what I got and was thinking of buying some wide angle iron, welding it to the frame, the drilling holes for the carrier bearing.
Any other ideas?
Backpayne is offline   Reply With Quote
Old 10-24-2021, 09:41 PM   #2
PGSigns
PGSigns's Avatar
Re: Need help with some redneck engineering
The best way to fix it would be to start over. Looks like the rear drive shaft is about a foot to long. The trick had a light duty carrier bearing in it at one time. You can see the remaining parts of the bracket. You have the HD bearing in it now. Post some pictures of the rear end of the drive shaft and the trans end (over all pictures of the drive shafts) and we may be able to get your problem worked out. Need to get the angles worked out and come up with a solution that will last.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-25-2021, 04:00 PM   #3
val1gonzales
I don't think that cross member is for a two piece shaft because the mounting holes aren't on the crossmember. Maybe last owner just used what they had readily available. Check out this thread.http://67-72chevytrucks.com/vboard/s...d.php?t=630898
Maybe just scratch it all together and get a single drive line. Or, make a bracket to work like the original ones pictured in the thread.
val1gonzales is offline   Reply With Quote
Old 10-25-2021, 04:23 PM   #4
Backpayne
It actually is a correct crossmember for the hanging light duty bearing, everything was just torched off. I'm pretty sure the driveshaft currently in it is just from a different vehicle.
I think I'm going to eventually get a one piece driveshaft but until then I'll weld up some angle iron to mount the carrier bearing support
Old 10-25-2021, 08:39 PM   #5
65truckowner
65truckowner's Avatar
I have a parts truck with the set up you need if interested. I have the driveshaft and the carrier
65truckowner is offline   Reply With Quote
Old 10-26-2021, 12:04 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Cpp sells this set up. I was thinking of going with it since two of the other style bearings failed on me. https://www.classicperform.com/Store...Truck/CSBC.htm
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-26-2021, 01:18 PM   #7
pdxhall
pdxhall's Avatar
I would start over. I wouldn't want to risk a failure and possibly mess up the rear end and/or the transmission. Then you'll have even more of a problem.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
