LS Turbo'd Guys... Suggestions needed!!!
I currently have a 6.0 LQ4 at the machine shop that I have no money into it. I got the motor running with low oil pressure because the cam bearing walked.
I was going to do a simple rebuild and although I have no experience with turbos, I can't shake the idea of building a twin-turbo build. I guess I just want to do something different. I plan on building the motor first and then decide which truck I want to put it in. I currently have an 86 GMC C3500 RCLB and a 86 RCSB C10 with no motor or transmission, and a factory 86 2WD Jimmy that runs with a 305/700r4. I jumped headfirst into the turbo idea and purchased the ARP Main Studs, Connector Rod Bolts. My first question is, is it even particular to have a twin-turbo'd truck as a daily driver? If so, what would you recommend?
Instagram: @petestruckfarm |
| Bookmarks |
