Switching power steering gear box problem
A few months ago I was having trouble with my power steering gearbox. The mechanic was going to switch it out for a new one. I decided it would be a good time to change it to a gearbox to one that would have a quicker turning ratio. When they did this is really screwed up my turn radios. Has anyone else had this problem? Any ideas?
Re: Switching power steering gear box problem
So, how many turns of the wheel does it take you to go from stop to stop? Also, is th ox at the mid-point of its travel when the wheels are staight? Im not clear on what exactly is meant by a screwed up turn ratio. I have a power steering conversion and my truck turns a bit sharper left than it does right, but I attribute that to the mounting bracket spacing the box away from the frame.
Sorry I wasn’t clear. I meant that the turn radios was much tighter with the old box than it is now.
I will have to check on how many turns it now takes. |
When it came to the stock power sfeering boxes for a 70's/80's C10, the quicker ratio box was 3.3 turns lock to lock and those started later in the run. Before that they were 4.5. Another consideration is the pitman arm. If yours was perhaps changed to something shorter than before, it would have an adverse effect on the radius.
Huh, I was looking at the parts list on my Receipt. It doesn’t show a new pitman arm. If my memory serves me correctly the steering linkage is so close to the front of the cross member that if the pitman arm was any shorter the linkage would contact the cross member.
#6 | |
I should have stated what I meant by that. The pitman arm on the old gear box made things so close that they almost touch. So my thinking is if they shortened it when installing the new gear box then it would probably would have made contact. So I am thinking that they probably did not switch it out. The boos out of town at the mechanics that I took it to. So I am not able to ask him about it until Monday
so whats screwed up?
explane
1961 chevy K10 my build is------------61K10 build |
I have much larger turn radius with the new quicker ratio gear box, than I did, with the slower ratio gear box. Or in the most simplest of terms, my wheels don't turn as far as they used to, in both directions. I am not trying to be sarcastic or sound like I am talking down. I just seem to be having a hard time describing a simple thing.
Moderator
![]() ![]() Join Date: Aug 2011
Your not. It was just difficult to understand. I wonder why it turns less tight? I'm going to have to check mine out also, i keep thinking it shoul have a tighter radius.
When I turn the wheel to the left it turns 2.5 times. When I turn it to the right it turns 1.25 times. It is 2.75 turns from lock to lock. There’s nothing that I can tell that is interfering with the rotor assembly and tires that is keeping them from turning any further from what I can tell. Here are some photos I took of the wheels at full lock. Tomorrow I will look underneath to see if there is any interference in the linkage.
Moderator
Remove the pitman arm, center the steering box from right to left and re-install the pitman arm.. or center the steering box then remove the pitman arm, center the steering wheel and re-asemble. Or take it in and have it done for you.
#13 |
![]() ![]() ![]() Join Date: Jan 2018
I agree that it doesn't seem the box is centered properly
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#14 |
I agree also but even with that being said I still think that it is not turning enough especially if it is supposed to have 3.3 turns like AcampoDave said earlier.
#15 |
The 3.3 that I mentioned applies to the oem boxes for 70's and early 80's trucks. Is it possible you have some other kind of box? Also I had a question about Rocknrod's idea of recentering the pitman arm on the box... isnt it made with one spline that is wider than the others so that it can only be clocked in a specific position?. I seem to remember something about seeing that on mine. Also if you were to disconnect the tie rod and recenter that, you would need to take up the difference at the ends which might necessitate a toe in adjustment when all is said and done.
#16 | ||
Moderator
#17 | |
I guess that I am assuming that the gear box has some kind of built in stops. Is that true or would it just keep on turning if disconnected from the pitman arm? |
#18 |
Moderator
No it wont keep turning, and your spindles have stops also at the A-Arm most likely if they're not stock (mine do, POL). I forget if the stock ones do.
#19 |
I have cpp spindles and they don’t have stops
#20 |
I took a look underneath this morning at full lock on both sides there’s no interference. The pitman arm looks like the same one as the one I installed when in installed it with the old box. When I look at the splines on the steering box the notch that is in the splines to locate the pitman arm is facing straight forward. The only thing I can think of that is effecting the turn radios is the actual box. There is a small whiteness mark on my sway bar where it looks like my tire had made contact and the tire was around 1.5” away from it at full lock. I am thinking that it happened with the old box. When I had my truck at the transmission shop the other day he felt that it was almost undrivable as far as the tun radios goes.
#21 |
Sounds similar to the situation I had when I converted to power steering. I turned the box to center the output shaft of the gear box by turning lock to lock then installed the pitman arm which can go on in four different locations, installed my rag joint and put it on the truck. I took it to the shop to get it aligned and on the way home almost missed my driveway. Turned all the way to the left but not to the right. I took the truck to another alignment shop and they had to remove the pitman arm and rag joint, re-center the box, and adjust the tie rods which were no where close to even. So long story short I had set up the gearbox wrong when I installed it.
#22 |
My turn radios is bad in both directions. I’m not sure if the slight difference from side to side is my biggest problem.
#23 |
I guess I'd put the front on some stands with the wheels and suspension hanging free. Then, I'd slide under, grab a wheel and watch as I turned turn back and forth. If that revealed nothing certain, I would then disconnect the tie rod at the pitman arm and give the box a back and forth checking to see if the tie rod assembly is the limiting factor or if it's the box itself. Hopefully, that would provide a clue. Then after correcting any obvious problems (i.e. upsidedown or backwards tie rod) I would center the box in it's travel like this... https://youtu.be/LlhUaoE4zBo
Provided the tie rod is proper and the pitman arm is clocked correctly on the box, I would keep my steering wheel centered as in the video, then center my wheels and adjust the end links until the eye of the tie rod landed "boom" dead center on the pitman arm stud. With a power steering conversion adapter plate on the frame, it's likely the end rods will be unevenly adjusted with regard to left and right since the box itself is spaced off the frame by the width of the adapter. I would not be shocked if I had to give up a bit of right hand radius so as not to overextend the threads of the endlink on one side. After that it would be likely that the steering wheel would need to be removed and recentered. Edit: as an afterthought it occured to me that if my lock to lock turn count was markedly lessened upon reconnecting the tie rod, I would surmise that the problem lied within my suspension as opposed to the box. Last edited by AcampoDave; 10-31-2021 at 02:40 PM. |
#24 |
If I don’t take it to the mechanic that messed it up by next weekend I am going to turn my wheels from lock to lock and mark the position of the pitman arm. Then I will disconnect the pitman arm from the linkage and then see if it is stopping at the same location.
