Broken heater hose coupler extraction
I’m finally getting to hooking up the engine a year after bringing my truck home from the resto shop. I found the heater hose quick disconnect snapped. I have watched several videos to get an idea of how to proceed. Most of the videos show the Lisle 62200 removal tool. There is also a Napa version that looks more square peg shaped, and a tool that looks like a screw extractor. I’m considering trying the screw extractor. The other tools require pounding it in and from the videos it looks like the brittle coupler piece partially disintegrates from the hammering. Does anyone have any experience with any of these extractors?
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
![]() Join Date: Jan 2003
Re: Broken heater hose coupler extraction
Use the OEM one, and gently tap on it to seat it. Then back out your connector.
1969 307, t3501950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
If you can't back it out, you can cut it from the inside with a small hacksaw blade. make a few cuts, then you should be able to get the pieces out. You would then need to vacuum out the debris or flush it out.
Mike |
I put penetrating oil on it for 3 days, then finally got the extractor. It came right out.
I watched a few videos of the hacksaw method and did not want to go that route. I also saw one video of the extraction kit from Lisle, but it looks like that is discontinued. I did find a tap that comes with drill bit, so if I have to do this on my other truck at least I know some options.
| Bookmarks |
