10-30-2021, 02:37 PM | #1 |
Were all 73-87 wired for a cigar lighter?
My 78 did not have the RPO option for a cigar lighter and it has the metal delete where the lighter would go. On a 78 I know the wire is orange that goes to the lighter. To my surprise there is a orange wire that terminates right behind were the lighter would go. Were these wire for a cigar lighter even tho it was a delete?
10-30-2021, 03:04 PM | #2 | |
78 Big10 454
Re: Were all 73-87 wired for a cigar lighter?
1978 Chevy SWB C-10 2WD 454/400 |
10-30-2021, 03:46 PM | #3 |
10-31-2021, 03:17 AM | #4 |
78 Big10 454
Casco
10-31-2021, 02:08 PM | #5 |
10-31-2021, 03:52 PM | #6 |
78 Big10 454
Yes, just the orange wire to the terminal on the back of the lighter. Very easy hook-up.
11-05-2021, 09:44 AM | #7 | |
11-05-2021, 12:06 PM | #8 |
I mostly want to use the cigar lighter outlet to power a usb adapter to charge my phone. Do you think the wiring on these old squarebodies is up to the task?
11-07-2021, 10:04 AM | #9 |
If the wire was never used it used be like a new for 1978 wire. If I remember right the lighter has power all the time when plugged in so do not forget things plugged in the can't be turn off unplug be for you leave the truck for safety reasons.
Or the truck batt going week or dead. Power will go up a little when charging under rpm with socket of lower drawing Accessories (there is no safety soft ware on that socket other then the 30AMP fuse. So if you have a all most dead phone I would charge only 20 -30 min at a time for batt heat on the phone batt, to much heat on the batt shorten on lots off charges your Batt life span. To hot of a phone batt does not hold the charge as long. Or get a auto sensing Dc socket adapter with chip board regulate power from the socket for soft wear phones pc Tablets.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
