Old 10-30-2021, 08:46 PM   #1
65truckowner
65truckowner's Avatar
Just cant do it
I found this poor 66 the other day and was able to buy it. Some how the frame behind the cab was rusted in half. There was hardly any of it left but the cab forward is fairly solid. I was going to part it out and use some parts for my truck I am building but I have a swb frame found and will be putting this thing back on the road. It has the 283 and 3 speed still in it. The dash is real nice and the radio has not been cut.IMG_4437 by Daniel Crymes, on Flickr
65truckowner is offline   Reply With Quote
Old 10-30-2021, 09:08 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Just cant do it
That does look nice. I wonder what happened to the bed?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-30-2021, 09:24 PM   #3
65truckowner
Re: Just cant do it
If you look behind it that is what is left of the trailing arm. I dont know if it was full of fertilizer or what.
Old 10-31-2021, 10:00 PM   #4
LVPhotos
LVPhotos's Avatar
Re: Just cant do it
I had friends on ranch day 1... 40 Ford truck no bed used as belt drive for water pump. Still sits in its first and only spot
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
