11-04-2021, 02:17 AM | #1 |
front inner fender fitment question
Does the front inner fender have some adjustment? I needs to align with the holes on my fender.
11-04-2021, 10:03 AM | #2 |
Re: front inner fender fitment question
Body parts often need a little adjustment to fit. Be aware that there are two inner fender styles. One for 73-80 and a different one for 81-87. The styles can be made to fit on the other style but you will likely have to add a hole or two to the inner fender. At least in fitting a newer inner on a 75.
11-04-2021, 10:28 AM | #3 |
I'm replacing my rocker. I have a new OEM GM fender. I'm using my original inner fender. I'm less concerned about the fender fitment and I'm trying to get the door fitment right with the rocker. I then put my fender on and I see that the holes are not aligning with the inner fender. I have not tried to loosen my inner fender.
11-04-2021, 04:07 PM | #4 |
I just recently replaced drivers fender with used dent less fender. I used a screwdriver to line up holes in fender and wheel well. I had a heck of time getting the used fender to match up to the radiator support as well.
79 Chevy 2wd BIG10 350 TH400 |
11-04-2021, 04:53 PM | #5 |
That is my concern. Did you try loosening the inner fender to see if it could be adjusted?
