12-27-2003, 03:46 PM | #1 |
F.A.S.T. president
dam... I screwed up
I just couldn’t get the %#@!$% adjustable track bar to work correctly in *%$#*@ stock position. So I had to take off my %$#@!* trailering arm and fabricate a bracket to mount a track bar in a similar position to the ECE kit. It *%$#@% sucks to have to take a grinder to and weld an already painted part. Now I just have to fab an %#@!&* 11" longer track arm. I would have bought the ECE kit but the bracket for the trailer arm would not work with my C-notch. Sorry...I just had the releive some stress before I take a hammer to my truck
12-27-2003, 09:42 PM | #2 |
Project92 SWB stepside
It wil be OK put the GUN DOWN!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
12-28-2003, 06:12 PM | #3 |
Progress = 0%
Are you sure that is going to work with the c-notch???
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
12-28-2003, 08:42 PM | #4 |
F.A.S.T. president
@Slammed67
yes, I already tested it. I remember seeing the picture of your set up when you had the problem with the c-notch and the trackbar. The diffrence is the diff sits on top of 2" block with the welded tabs, so when the top of the axle housing bottoms out on the c-notch those tabs are still under the frame. Its basicly in the same postion as when you welded the tabs to the trailering arm. The ECE brackets put the bar along side the axle housing. Mine is sitting below the axle housing just like yours. (thanks for the tip) Last edited by jamis; 12-28-2003 at 09:49 PM. |
12-28-2003, 08:59 PM | #5 |
F.A.S.T. president
Here is a picture if it on the truck, sorry but I already have the springs on it so I cant take a picture of it bottomed out. Those red lines represent where the frame and c-notch would be in the bottomed out position. The picture sucks because of the flash. Makes me wish I had painted my frame the satin black like yours.
12-29-2003, 11:17 AM | #6 |
Progress = 0%
I gotcha..... that makes sense now.
