Old 11-04-2021, 06:07 PM   #1
DT1
DT1's Avatar
Noisy Belts
https://67-72chevytrucks.com/vboard/...ht=noisy+belts
I just dug this up from the search area. I'm curious to know if anyone else has tried Dielectric grease to their belts to silence them. If so, How much will do the trick?
DT1 is offline   Reply With Quote
Old 11-04-2021, 06:24 PM   #2
BigBird05
Re: Noisy Belts
I would think that Dielectric grease would make them more likely to slip. If they are squeaking or screeching you should try V grooved belts.
BigBird05 is offline   Reply With Quote
Old 11-04-2021, 09:13 PM   #3
Sheepdip
Sheepdip's Avatar
Re: Noisy Belts
I've never tried it but I watched an old guy put a bar of soap to the belts pulley riding surface and it worked.....for how long I do not know.
Sheepdip is offline   Reply With Quote
Old 11-04-2021, 09:16 PM   #4
Grumpy old man
Grumpy old man's Avatar
Re: Noisy Belts
X1 ^ it works , Takes the glaze off the pulleys . Just rub a bar of soap on the belts while the engine is off
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 11-04-2021, 10:13 PM   #5
Getter-Done
Getter-Done's Avatar
Re: Noisy Belts
I just told the People at work this Today
They called me a Used Car Sales man
It works
84 Chevy K-20
Old 11-05-2021, 02:17 PM   #6
DT1
DT1's Avatar
Re: Noisy Belts
I've used bar soap a few times. It does work but only for a day or two.
Old 11-05-2021, 02:18 PM   #7
DT1
DT1's Avatar
Re: Noisy Belts
It works
Do you mean the dielectric grease works?
Old 11-05-2021, 03:31 PM   #8
Impact02
Impact02's Avatar
Re: Noisy Belts
I have used dielectric grease to fix squeaking belt on my 96. Use just a little bit. Baby power works too.
Impact02 is offline   Reply With Quote
Old 11-05-2021, 05:37 PM   #9
Getter-Done
Re: Noisy Belts
I was referring to the bar of soap trick
It only last a short while thou.
84 Chevy K-20
Old 11-05-2021, 08:50 PM   #10
cj847
cj847's Avatar
Re: Noisy Belts
Don't be so cheap and go buy a spray can of belt dressing.......
cj847 is offline   Reply With Quote
Old 11-06-2021, 04:51 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Noisy Belts
I tried that one time, many years ago. Didn't work worth beans, and made a sticky mess that was hard to clean up. Never again. YMMV
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-06-2021, 05:28 PM   #12
Accelo
Accelo's Avatar
Re: Noisy Belts
IMHO- Belt dressing is a car salesman stuff.
Save your money. Clean the pulleys and sand them lightly and put a new belt on it. Never fails. The belts with the notches on the inside work better than the smooth ones. They are rated for higher horsepower transmission. They are identified by the same number but have an X as part of the number.
Accelo is offline   Reply With Quote
Old 11-07-2021, 12:57 PM   #13
toolboxchev
Re: Noisy Belts
X2 on this, new belts, tighten them up to spec, and sand the grooves in the pulleys slightly.
After 50 years those pulley grooves are highly polished.
toolboxchev is offline   Reply With Quote
Old 11-07-2021, 12:59 PM   #14
toolboxchev
Re: Noisy Belts
Take the belt off and soak it, letting it saturate and dry...yeah it does only work for a couple months.
