Old 11-05-2021, 03:31 PM   #1
61K10
61K10's Avatar
instrument cluster clips
Hi all
I've had my instrument cluster in and out a few times. when installing the clips (that the screws screw into) keep pushing off the tabs. I have after market clips like the org ones. I might have to bend the dash tabs back some so the cluster slides in without contacting the clips? Anybody have this problem? 61 dash by the way and I only want to do this one more time.
thanks for any info----------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-05-2021, 04:01 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: instrument cluster clips
I think you should be ok to bend the mounting tabs back a little bit. As the screw tightens up, it'll probably pull the tab back in some
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
