11-05-2021, 05:06 PM | #1 |
Recommended Pan Plug Seal
I've had an oil leak for some time now, so I changed my oil a few days ago and found that the pan plug had somehow worked it's way loose. Not so loose to fall out but loose enough to leak. The only reason I can think this would occur would be a damaged or incorrect sealing washer.
The last time I changed the oil I used an aluminum crush washer, so I figured I'd try a different material. This time I installed a nylon washer and it didn't leak a drop for three days. I backed the truck out today and I noticed oil on the floor. When I checked the pan plug, it was loose again. Now I'm not sure what material sealing washer I should use. In both cases the plug was tightened properly. Any recommendations will be appreciated. Last edited by DT1; 11-05-2021 at 05:24 PM. |
11-05-2021, 05:32 PM | #2 |
Re: Recommended Pan Plug Seal
Nylon is original equipment AFAIK. Maybe the threads are worn on the plug or in the pan?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-05-2021, 05:45 PM | #3 |
11-05-2021, 07:56 PM | #4 |
Maybe a oversize plug or try a copper crush washer first?
Link: https://orv.livejournal.com/327244.h...d-tight%20seal.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
11-05-2021, 10:02 PM | #5 |
I use a relatively thick cardboard style washer, works for me just fine without any issues. I think it may be about 3/32 thick
11-07-2021, 11:52 AM | #6 |
Been happy with these.
https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds |
11-07-2021, 12:47 PM | #7 |
That thing should never come loose on its own. You have some type of issue, maybe even a metric bolt. I use a copper washer now due in part to the nylon one being 50 years old, neither loosens on its own.
11-07-2021, 11:28 PM | #8 |
The plug didn't come loose if it was tight in the first place. You evidently forgot to tighten it, happens to best of us.
11-08-2021, 02:02 AM | #9 | |
11-08-2021, 12:21 PM | #10 |
11-08-2021, 12:55 PM | #11 |
Maybe somebody else is messing with it then. we had an idiot at the dealership about 25 years ago that was trying to get the lube guy fired b'cuz he didn't like him and was pulling that ****. Lube guy was on though and got him fired and luckily there were not any customer cars that got damaged.
11-08-2021, 01:26 PM | #12 | |
This truck has never spent a single night outside since I took ownership of it in 1999. And, although I drive it every day (Except when it rains) It's never left out of my sight. I consider it "The vehicle I drive when I have absolutely no where to go". Since it's the original pan plug and I have changed the oil every 3000 miles (Tightened the plug EVERY time) since I have owned it, I'm thinking the plug is probably ready for a 1st oversize. |
11-08-2021, 07:06 PM | #13 | |
ETA, if the threads are bad it won't tighten in the first place. Last edited by garyd1961; 11-08-2021 at 07:20 PM. |
11-09-2021, 09:32 AM | #14 |
https://paceperformance.com/i-648519...ain-plugs.html
or buy from your local GM dealer. These seal better IMHO than the stock ones.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-09-2021, 02:53 PM | #15 |
I fixed mine by using a flat washer and O ring. The washer has an ID slightly bigger than the O ring OD and is about .015" thinner than the O ring. I've done this on a couple engines and have never had a leak.
11-10-2021, 02:27 PM | #16 | |
